7.90
Thanks. I use Starnet2, where there is no such "unscreen star" option. I will continue to experiment and post results. Of course there is: It is called "Create starmask". |
3.61
andrea tasselli:Thanks. I use Starnet2, where there is no such "unscreen star" option. I will continue to experiment and post results. Oh ! okay. I thought that Matija was refering some additional option available in StarX, other than the very fact of removing the stars. Well, then I guess there is not other way around that continuing to play with option. But I still have little success with this method. |
Well, then I guess there is not other way around that continuing to play with option. *There is a processing icons pack that I downloaded from Lukomatico on youtube and it has icons that you can try using to screen the stars back in. Might be a good shout to think that there's probably a difference in how starnet and starx remove stars, so the technique might require some adjusting. Also keep in mind that I'm no expert in this so I might not give out the best of advice 😅 cs, Matija |
7.90
To get the stars back in the starless image use ~((~starless)*(~star)) in PixelMath |
