Narrow vs wide. Light pollution gradient. [Deep Sky] Processing techniques · Sean Mc · ... · 2 · 137 · 0
smcx 3.01
Ok so let me preface this by saying that I’ve put very little thought into the subject lol.
So lets say you live somewhere that causes a strong gradient.
Does it make sense that a narrower field of view would produce images with a less severe gradient than wide field images?
As in… a narrow field image would be easier to correct?
Thoughts?
Staring 4.40
Yes, that‘s basically correct (for my light pollution): The gradients in my 500mm FL images are far more complex than at 1600mm FL. There‘s also the possibility of using a wider-field FOV to correct the gradients in the narrower field. I‘ve used that technique and it worked well.
astronomical_horizon 0.90
I can agree with Torben. Got 250mm and 1200. the gradient is stronger with 250mm
