Tweaks for the Star Adventurer GTi Sky-Watcher Star Adventurer GTi · Michael Ring · ... · 11 · 1096 · 4
MichaelRing 3.94
It would be nice to know how others have tweaked this nice little mount to make it even better.
From my side, the one tweak I did and that I can highly recommend is to replace that very short Vixen Clamp with something a lot better.
My issue with this clamp is that it is simply to short to properly grab the Vixen Style foot that comes with the Ascar acl200.
So what I did was to order a clamp that is suitable for both Vixen and Arca Suisse dovetails from Teleskop Express in Germany.
Then I 3D printed a small adapter to fit the screw holes of the custom clamp to the  holes of the Skywatcher GTi.
Here's a closeup of the adapter plate and the clamp:
and here the fully mounted scope:
and here's the STL in case anyone is interested:
Skywatcher GTi Adapter v2.stl
MichaelRing 3.94
Forgot another tweak I did, a short extension for the counterweight bar which allows me to put the Askar in balance, it consists of a simple M12x60 Screw surrounded by a 3d printed part that has the same diameter as the original bar.
MrPhoton 0.00
Hi
To 3D-print the counter weight extension is a good idea! Thank you for this!
For the dovetail, I need to check my needs with my equipment.
Thank you for sharing!
Clear skies, Jens
drpafowler 1.51
Where did you get the mount for the EAF?  I like it mounted off to the side like that.
MichaelRing 3.94
I designed & 3d printed it myself, only thing to buy is the GT2 belt, here's the STL:
ACL200 ZWO Autofocus v1.stl
Piermi 0.00
Hi Michael,
I'm looking for a similar setup. Can you share the clamp bought from Teleskop Express?
Kind Regards,
Piermi
MichaelRing 3.94
Here's the link:
https://www.teleskop-express.de/shop/product_info.php/info/p11413
Piermi 0.00
Michael Ring:
Here's the link:
Thank you very much.
P
BenVonPrank 0.00
I had the same issue ! And also designed a 3D printed adapter - but for another clamp style
The clamp I had is the same as this one : https://www.aliexpress.com/item/4001098158402.html
and here is the adapter STL : https://www.printables.com/model/388265-star-adventurergti-replacement-vixen-adapter
It carries my Zenithstar 61II + reducer + guide scope + Asiair without issues.
afettoxiulong@gmail.com 1.20
Michael Ring:
*** Thank U very very much!!! ***
galaxysim 0.00
Michael Ring:
Hi, do you mind sharing the STL for the counterweight extension bar? I was thinking of designing something exactly like this!
Vagonsky 0.00
Michael Ring:
IMG_1237.JPGGood idea. Could you share the STL for this, please? Thanx in advance
