Hello,
While the manual states that the polar scope should be fully inserted to the SAM exposed hole (page 32), I can't push the scope far enough into that hole. I assume that the three bearings of the SAM hole should enter the groove of the polar scope, but I can't achieve that. Is this normal?
Their polarscoe is rubish. They didnt even put illumination in it...
Problem solved.
For future reference, here is how I did it. No special tools are needed; in a well-lit environment it can take less than 30 minutes. You need two screwdrivers and an Allen key. As always, take care not to loose any screws
- Remove the four screws which holds the plastic cover located at the USB port side.You may remove both covers for your convenience.
[/*]- Use an Allen key (I used the one provided with my photo tripod) to remove the two screws which holds the gear mechanism over the central tube.[/*]
- Loosen the two black screws on the opposite side to remove the gear mechanism.[/*]
- Now the central tube can be rotated and the three screws which control how deep the ball bearings go, can be conveniently placed for you to loosen them. [/*]
- Loosen them until you can fully insert the polar scope.[/*]
- Re-tighten the three screws in a symmetric manner until the polar scope rotates without play and be easily removed/inserted.[/*]
- Reinstall the gear mechanism and close the cover.[/*]
After these steps the polar scope can be fully inserted and there is no considerable play when you rotate it.
The good news is now I can easily confirm that my polar scope does not need calibration!
Maybe waking up a dormant thread, but I just want to say that there was no problem with those ball bearings on my Star Adventurer Mini. And to Alan's comment above, I just want to say I think the polar scope is good, and yes, it comes with illumination - not in it, but as an external thingy, which you can use when needed. So far very happy with the SAM.
to create to post a reply.
