1.51
First Light QHY 268C Messier 51 ( chefjedidiah ) - AstroBin Please roast me, as they say. |
1.51
100+ views and no one has anything to say? Must be the perfect picture then? |
7.14
You need to pull out more saturation, the palette currently is just yellows and purples. Who knows maybe that's the real look of the galaxy but usually we see more color in those M51 pictures. Don't be afraid to increase saturation, possibly using the luminance mask to avoid colorizing the background. |
11.87
There are many M51 images on Astrobin which a simple search would reveal. Have you compared your image to them? What shortcomings, if any, have you observed? Your critique of your image matters more or should matter more to you than someone else’s opinion. RCC would be more beneficial to you if you ask for specific areas for improvement. |
1.51
This was shot unfiltered, and as such the colour is what it is. I am always weary of bumping the saturation too are thereby amplifying the noise. And at only 20 subs, I didn't want to push it too far. There is a slight coma near the edges, possible back spacing problem. I just wanted to know what everyone else saw could be improved. More integration More colour better colour balance tighter guiding smaller stars flatter background Thanks for looking |
11.24
You don't list any processing software and I am not familiar with QHY Capture but if it is like most other capture apps it has little or no processing functions. You have just enough integration time to naturally resolve some of the colors available in M51, but the color you have is not the predominant OSC color in the object. The key to knowing that is the fact that your background is the same color as the object and the entire object is that one color without any tonal variation between the light areas and dark areas in M51. This is called color cast. I think you are making a mistake by believing that dark magenta is the natural color you get for this target with your new camera and @Arun H. is absolutely correct advising you to search the best OSC images of M51 to see the colors and look at the technical cards to see what others are using to process those colors. Almost every processing program will allow you to manipulate a multitude of parameters including brightness which this image also needs. Most around here will also advise you to acquire and learn to use a dedicated Astro imaging program such as Pixinsight or Astro Pixel Processor. Unfortunately there are no shortcuts in this hobby and imaging and processing skills take a lot of practice. Specifics, Always as much integration as you can get Yes more color and tonal variations of colors including color luminance. Your image has NO color balance I suspect you already know your guiding is good re: 10 minute subs Do you really think your stars are too big? I have no idea what a flatter background means, start by losing the color cast Good Luck scott Here is an more or less average M51, there are many many more... M51 Wide, OSC |
