This is my best image yet. https://astrob.in/j39mte/0/ All processing was done in PixInsight. WBPP with CosmeticCorrection was used with 30 flats and 30 flat-darks. 25 600s exposures were taken using the L-extreme filter. RGB channels were extracted from the stacked master. A color image was then made using PixelMath as follows: R: .917*R + .071*G + .0336B (simulated Ha channel) G: .083*R + .929*G + .9664B (simulated OIII channel) B: .083*R + .929*G + .9664B (simulated OIII channel) The idea here was to do a quasi-HOO palette. I'm not sure if I did it correctly but the resulting image was a bit better so I went with it. Thanks, Casey |
I managed to upload the wrong file earlier. Please see this link. https://astrob.in/357gyg/0/ |
1.51
Your stars are great to start with so that’s good, but it seems that your gain might be too low? Check your R channel I would recommend you try using that for Luminous and see What you come up with! |
