What am I missing? In tutorials it applies the correction; it's not the case when I do it. Thanks for the advice. |
1.81
The vignetting tool never worked for me. It is also only supposed to be used when you did not use any flats for image calibration. I would try to correct any gradients in your image with the remove light pollution tool. This works very well, usually. |
The vignetting tool never worked for me. It is also only supposed to be used when you did not use any flats for image calibration.I would try to correct any gradients in your image with the remove light pollution tool. This works very well, usually. Good to know I’m not the only one. That’s what I have been doing. Thanks! |
The vignetting tool was a gamble for me, too, sometimes good, sometimes white. Frankly, I didn't know what I was doing, so, not blaming APP. I changed to Fitswork for removing vignetting an uneven background. So far working great. |
