I need help to process my Cassiopeia image to pull out the dust lanes around it I can use PI and if needed PS (but my ps knowledge is 0) I have around 30 lights, 0 calibration frames What settings to use to pull out the lanes? The link to 1 raw image https://imgur.com/gallery/EHXYZpr |
Can you provide a link to the entire calibrated stack? Hard to tell from one subframe what's happening. You can try to use Enhance Dark Structures script in PI. I use this function in combination with PS by blending the "standard" image with the enhanced one until I get the desired effect. Clear skies, -Lloyd |
0.90
You need flat frames to eliminate vignetting and illumination issues. Then you can use an S curve to enhance over all contrast. This process will enhance the dust lanes. |
3.21
There are fantastic tutorials provided by Kayron Mercieca. I suggest to use this one: Andromeda processing Tutorial |
2.81
Try the dark structure enhance script in PixInsight. Edit: I see someone has already suggested this. |
