Hi all, I just published a new script (for Pixinsight) to convert Osc dual band images in RGB format to a HaOO image. I used the script to process this image https://www.astrobin.com/4zy08q/.
If you would like to download it, then you can find it here:
https://www.paulkline.com/script
Clear skies,
Paul
Can't wait to try this, thank you!
Connor Kessler: Can't wait to try this, thank you! Gave it a shot on a heart nebula crop of mine. Flawless script!
Connor Kessler:
Connor Kessler: Can't wait to try this, thank you! Gave it a shot on a heart nebula crop of mine. Flawless script! I am glad that you like it. It saves me a lot of time. Thanks for the feedback.
I got the Script. Can't wait to try it.
Thank`s Paul,
first trials worked well!!
Frank
Clear skies,
Paul Nice! Thanks for sharing. I do all this manually in PI by separating the channels and then combining to make new ones etc. (for example this image) So I shall try your script out and see how it compares
Hi Paul. Nice work! The script works well!
I'm new at the dual-band filter stuff and there is lots to learn. The few images i tried processing, invariably ended up quite uniform in color. I think I understand what the script does and i'm aware of the possibilities, but i never attempted to perform these actions manually.
So I tried this script and it magically adds a lot color depth to the image!
There is a lot to investigate, but I'm already sure i'll be using this often. Thanks a lot for sharing this!
I haven't tried the script but have many PixelMath expressions saved to do similar things. I'm curious about how OIII is built in the script though. You're using "max(Green,Blue)". I've used "Green*2/3+Blue/3" because of the bayer matrix, 2 green for every 1 blue. Given the overlap of green and blue this seems a more true translation of the dual-band data. Have you tried this instead of max of the two channels? I will have to go try out max sometime this weekend, and this script. Thank you for sharing |
Hi, I have tried different ratios of blue and green. But, I favor max(blue,green) to gather the O III data. I may add the ability to select between the two options in a future version. I really appreciate your input.
Thanks
Paul
to create to post a reply.
