Cookie consent
I agree
Camera help
jamesmdmad
04 Jan, 2019 10:48
Hi all .
Has anybody compared de NikonD810 to the D850 for deep sky photography ?
I have a d810 and I’m happy ( but I have no idea yet ) but I have a great offer for aD850, is it any better?
thanks
James .
Morian
04 Jan, 2019 10:50
ZWO ASI1600 MM PRO is better👍
jamesmdmad
04 Jan, 2019 11:13
Morian
smile , yes that would be another option. Thanks .
but witch of the two nikon is best ?
I would stil ha an all purpose camera with a DSLR.
Cheers
james
Morian
04 Jan, 2019 11:31
I have a Canon 500d that was modified by removing ir cut filter and a Canon 6d not modified, cus when someone comes up whit a good project it is still wunderfull to look.
I have the ASI1600MM pro and its a great ccd camera but when you lay an effort work in DSLR it has a macic glove in the image that manny ccd cameras still lacks off.
What I try to tell you is learn your equepment and Grove from there.
Best of Luck to you.
jamesmdmad
04 Jan, 2019 11:40
Morian
I have a Canon 500d that was modified by removing ir cut filter and a Canon 6d not modified, cus when someone comes up whit a good project it is still wunderfull to look.I have the ASI1600MM pro and its a great ccd camera but when you lay an effort work in DSLR it has a macic glove in the image that manny ccd cameras still lacks off.
thanks , that I bet is the right thing to do .
Cheers
jamesmdmad
07 Jan, 2019 18:29
Is it worth trying to build a “cooling box” for my camera (d810) I’m thinking of summer nights around MADRID , Spain .
I’ve heard of a camera modification that doesn’t involve any cooling system,  anyone has it ?  It’s done at Spencer’s camera Here
cheers
Morian
07 Jan, 2019 21:23
It canno payoff.
I was thinging the same time a go, the Best way to get the Best Out of a dslr is to imageing when its biting cold to reduse noise.
The Canon 6d has werry little noise but you have to save up to get a mono ccd whit cooling.
Thats the Best advise I can give you.
carastro
08 Jan, 2019 11:31
I had a DSLR for a couple of years but became frustrated with the noise.  Bought a Cool box but found it such a faff to operate with the box around the camera (as then unable to get at on/off switch and Mode switch, plus the camera came out soaking wet afterwards which worried me, so I stopped using it and ended up getting a Cooled dedicated mono camera.
I rarely dabble in DSLR imaging these days but sometimes there is a reason why, and when I do it reminds me why I changed to a CCD camera.
Personally I would not waste time  and money buying a second DSLR.  If you already have one fine, but if you are going to buy again, I would get a dedicated cooled camera.
Carole
Edited 08 Jan, 2019 11:32
