Planning tools; suggestions
ojaigsguy
06 Jun, 2018 04:15
I've been imaging off and on for about twenty years.  I often struggle to decide what objects or regions I would like to image on a particular night. These days I am using SGPro to set up sequences in advance, but making a new selection is often difficult.  What do you use to decide?  Astro Planner? The Sky? Other images from Astrobin? Articles? What?  Does any use books any more, like The Cambridge Star Atlas?  Any other resources you can suggest or advise against.
Thanks for the suggestions.  Jeff
powerstroke01
06 Jun, 2018 04:22
Id also like to know. I just spin a globe and land my finger so to speek. smile
Clearskys
06 Jun, 2018 07:54
Hi  Jeff! I often use Stellarium to choose and plan in advance what to shoot. But I struggle any way, like you every time I have to decide what object to shoot. The worst is when I choose an object that than, when I’m out, it reveled to be too low anyway and the back up plan too. When I did not plan in advance I use Stellarium too, but also Star Chart (on my Iphone). I of course get suggestions looking what others shoot on Astrobin.
khrrugh
06 Jun, 2018 09:50
Hi Jeff,
my first step is to look what others on AstroBin are imaging, look at a few magazines or websites or search on google. My second step is to use the Imaging Toolbox or Astronomy.Tools to see if the target suits my setup. I then take a closer look at the ephemeris at what time the object can be seen at my site. Last but not least i track the object with Online Planetarium to see exactly at what time the object is how high in the sky at a given date.
Hope this helps,
Michael
craig_rodgers
06 Jun, 2018 10:09
Another good option is https://dso-browser.com it will tell you what is in the sky at your location tonight, or any date in the future.
Die_Launische_Diva
06 Jun, 2018 13:36
Hi Jeff,
I use Stellarium and its Oculars plugin, in which I've entered my camera and lens details in order to be able to visualize my imaging setup's field of view against the night sky. It is a tremendous tool for choosing targets and for framing. Version 0.18 added support for a multitude of surveys, including Axel Mellinger's Milky Way Panorama (for planning widefields) and e.g. the so-called PLANCK R2 HFI color composition 353-545-857 GHz (if you are interested in dusty stuff!)
Also, AstroBin (of course) for searching of what other people have achieved with equipment similar to mine, Wikipedia and astronomy-related magazines for getting clues about what are the "proper" colors of objects!
Clear Skies!
Clearskys
06 Jun, 2018 14:08
Oh very good that you mentioned the Ocular plugg-in, I forgot it! It is a great tool!
ojaigsguy
06 Jun, 2018 14:50
Wow, all great suggestions ! I too use DSO Browser, The best Astrobin images, Sky Safari , the Sky X and even the Cambridge Star Atlas.  Sounds like we all do the same thing generally.  It’s often a game of cat and mouse with object location, the moon, and ephemeris.  Last night, I decided to go big.  I started earlier than usual, planned to shoot in the east, starting over the galactic equator about 25° over my horizon with narrowbandon the Crescent Nebula. I have SGPro set up for for over 5 hours of data.  The first Two hours of Ha, look great so far, guiding was excellent.  It’s Nebula season!
Keep your ideas coming! This is a goood discussion.
GaryI
06 Jun, 2018 20:55
Jeff,
I tried various techniques before I decided to go all-in with Astroplanner.  I am glad I did.  It took a while, but it has some great  and robust features once you get to know the program.  In addition to the normal sorting by transit time, moon distance, object size, etc., I have various filters set up so that I can custom highlight objects in different ways - for my current optical train, for my assigned priority, and for objects I have not yet imaged.  I have input 700 objects from any source I can get my hands on - Astrobin, magazines, books, etc.  Each night I have a plan of objects to image throughout the night, plus a backup set of objects in a different part of the sky in case there are clouds.
Gary
Edited 13 Jun, 2018 02:09
ojaigsguy
06 Jun, 2018 23:13
Gary,
Astroplanner…looks complex, but it also looks like it has many very good features.. It must be excellent if you are using it Gary, you are a prolific and highly experienced imager.  Great suggestion, we should all check it out!  I'll check it out tonight.
Thank you.
HazelLE
08 Jun, 2018 04:02
Jeff, what I do partly is to download object catalogs from the internet such as The Sharpless Catalog of HII Regions and the DWB catalog of HII regions
around Cygnus X to name a few, Also I find that Astrobin itself is a good source of new material, GOOD LUCK!
VicV
10 Jun, 2018 16:57
Die Launische Diva
I use Stellarium …. Version 0.18 added support for a multitude of surveys, including Axel Mellinger's Milky Way Panorama (for planning widefields) and e.g. the so-called PLANCK R2 HFI color composition 353-545-857 GHz (if you are interested in dusty stuff!)
The new survey feature in Stellarium is amazing, thanks for sharing!
schmeah
10 Jun, 2018 20:21
I prefer to look for targets rarely imaged, that way I’m less likely to be disappointed when comparing my results to someone’s far better resultssmile Starry Nights (PP7) is a great source for locating and framing obscure targets. For example I’ll select a random galaxy, then select PGC catalogue, zoom in and oodles of surrounding unknown galaxies will appear as tiny oval outlines on my screen. My FOV is accurately represented, and if I find a nice tight group of ovals that fit in my FOV, I’ll get the info off the screen and search the internet for info on that particular ARP/NGC/UGC group or galaxy. If there are few images of it and it looks doable, I’ll give it a shot.
Derek
