Cookie consent
I agree
qhy 163m monochrome cmos camera 12 nm. Gain and offset
Bella123
02 Nov, 2019 20:43
Hi, everyone, I was wondering if I am using 12 nm. Narrowband filters for my qhy 163 m camera, should I use a lower gain and offset, because these filters have a wider bandpass, or can I use the same gain, offset as say 6 nm. Filters, and does anyone have a good recommend gain and offset for my 12 nm. Filters for the qhy 163? Any help would be appreciated. Thanks, Shawn
Fatimora
04 Nov, 2019 08:06
Hello Shawn, I am going through the same sort of learning curve as well and because of this I am including a link that I find helpful, hopefully it will help you also? https://www.cloudynights.com/topic/671241-another-what-gainoffsetexposure-should-i-use-for-asi1600/
As a reminder, the ASI1600 uses the same sensor as the QHY163 so the information you will find with that CN post should apply.
Fatimora
04 Nov, 2019 08:13
Also, this link has some very informative charts!!! https://www.cloudynights.com/topic/573886-sub-exposure-tables-for-asi-1600-and-maybe-qhy163/
Bella123
05 Nov, 2019 22:11
Thank you Roman, I will read the article you referred to, it has been a constant battle figuring out gain and offset. Clear skies! Shawn.
