Cookie consent
I agree
2 average scopes on 1 average mount?
TareqPhoto
26 Jun, 2020 06:05
Hey all,
Does anyone here placed two scopes of medium weight on a mount that is not rated for very heavy capacity?
For example 2 scopes by each is almost up to 10KG [with accessories] on a mount that is rated for about 20-25KG only
astropical
26 Jun, 2020 10:08
Hello Tareq,
Only when imaging on the Moon  smile
If you like your Skywatcher AZ-EQ6 GT Mount, then I would vouch against a 20kg payload. Mount manufacturers usually specify a maximum payload which should be taken with a grain of salt. You will definitely experience inferior tracking and guiding accuracy.
I once overloaded my Orion Atlas EQ-G which is about the caliber of your mount. I was painful to hear the gear worms crying.
All the very best,
Robert
sky-watcher
26 Jun, 2020 13:45
Hi Tarek,
I  have a Heq5 pro and I used it for years with 2 scopes, the total payload was up to 20 kg.
The recommended payload for the Heq5 is 12 kg
https://www.astrobin.com/s2vz81/?nc=user
Since about 2 years I have a 10" newt on the mount the payload is still about 20 kg
https://www.astrobin.com/255037/J/?image_list_page=10&nc=
I could and can do 20 minutes exposures.
I use the Lacerta Mgen2 autoguider with finderscope.
Since  about 4 years works reliable, with a payload of about 20 kg.
This is my experience, but I would not recommend for other people
cs johny
TareqPhoto
26 Jun, 2020 17:55
astropical
Hello Tareq,Only when imaging on the Moon  smile
All the very best,
Robert
I see, it is difficult to find two cheap telescopes then to keep the mount within limits without pushing it too much, and i keep seeing some people using something like 12" F/5 Newtonian on EQ6 which is on the limit or the edge of the mount capability and they said it was fine, how? And i was thinking about two small scopes not big, but even with two small if i add cameras and filter wheel they will be a bit heavy.
TareqPhoto
26 Jun, 2020 18:00
sky-watcher (johny)
Hi Tarek,I  have a Heq5 pro and I used it for years with 2 scopes, the total payload was up to 20 kg.
cs johny
Well, i wasn't looking for that much, i mean i have 6" F/4 Newtonian which is nearly 5KG, if i buy another same scope that will be 10KG total, and if i add accessories for both say both can reach nearly 15-18KG, then with something else like guide scope i have small lightweight one that will put me at around 20KG, is that possible?
Also if i go with smaller scopes like refractors, i still don't want to buy expensive refractor more than $500 or 400euro for one so both are nearly $1000 or more, i can buy two up to $800 or even $1000 only but no more, so i don't know.
Also my mount is AZ-EQ6, the top quality model of EQ6 mounts, they send the mount with extra saddle, i have that extra saddle which means it can go with two scopes, but i have to know what is the limits of those two scopes and which two not expensive.
sky-watcher
26 Jun, 2020 18:33
If you think this doesn't works for you, the answer is very simple,   don't do it. 😊
TareqPhoto
26 Jun, 2020 18:46
sky-watcher (johny)
I just don't know, it may work nicely or it may not work, so i don't have the answer, why did i ask then.
