Cookie consent
I agree
Attaching the ZWO 60280 GuideScope
HaydenWatson
17 Aug, 2019 03:41
smile  Hey everyone,
I have decided I want to have autoguiding in my current setup (Skywatcher 130pds). The autoguider setup I am looking at are:
https://www.bintel.com.au/product/zwo-asi120mc-s-usb3-0-colour/?v=8e3eb2c69a18
and the scope: https://www.bintel.com.au/product/zwo-60280-guidescope/?v=8e3eb2c69a18
Only problem is, I am unsure how im going to mount the guidescope to my main telescope. Here is an image of the T-Rings for my telescope:
https://imgur.com/a/8J8nio6
https://imgur.com/a/1uGD5ko
would purchasing another dovetail to go across on the top of the T-rings, then mounting the guidescope with screws work? The dovetail would be: https://www.bintel.com.au/product/skywatcher-dovetail-bar-20cm-long-metal-extrusion-and-metallic-green-anodized/?v=8e3eb2c69a18 which is the same as I have on the bottom of the T-rings already to mount the main telescope. I realize that the two holes in the Dovetail bar are very close together so I would possibly have to drill a new hole or two.
Is this the only viable solution to mounting this guidescope setup or is there any better way I could go about this?
If all else fails then I may just settle for the Orion Mini https://www.bintel.com.au/product/orion-mini-50mm-guide-scope/?v=8e3eb2c69a18 and mount it to the preexisting guidescope mount.
astropical
25 Aug, 2019 11:34
Hey Hayden,
The easiest way to attach a guidescope is in place of the finder scope. Perhaps Bintel
can offer you to replace the dovetail with a more common finder show rail. Else I would
go for the Orion. It is faster with F3.2 versus F4.6 of the ZWO guidescope.
The ASI120MC-S is an excellent camera for planetary, but the bundled ASICAP software won't
find a guide star when I point my guide scope (Svbony 60mm/240mm) at Messier 8.
It could be a setting problem on my side, but please consult Bintel about this before you buy.
It may be better to choose the more sensitive monochrome version, ASI120MM-S, for guiding.
Cheers
Robert
Edited 25 Aug, 2019 11:36
khrrugh
25 Aug, 2019 12:37
Like Robert said i would also suggest to use the monochrome version for autoguiding.
