DSLR w/ T-Mount: Landscape vs. Portrait Orientation Generic equipment discussions · schmaks · ... · 6 · 174 · 0
schmaks 0.00
Hi there,
How do you go about orienting your camera to frame the photo as you'd like (vertical or horizontal) when shooting DSLR with T-Mount? I imagine there will be many shots I'd like to shoot vertically, etc.
ODRedwine 1.51
Telescope service T2 rotator
https://optcorp.com/products/teleskop-service-t2-quick-changer-360-rotator-tst2rot?gclid=Cj0KCQjwj7v0BRDOARIsAGh37irqU8oxHTDTmVDGcOqZsgTUt5LNwhMWQnsJwarz9SRiDZMl6PLqIDMaAv92EALw_wcB
Although this  is 5.5mm thick it only adds about 100um to your backfocus (according to my micrometer) because the male and female threads overlap.
schmaks 0.00
David Redwine:
Telescope service T2 rotatorhttps://optcorp.com/products/teleskop-service-t2-quick-changer-360-rotator-tst2rot?gclid=Cj0KCQjwj7v0BRDOARIsAGh37irqU8oxHTDTmVDGcOqZsgTUt5LNwhMWQnsJwarz9SRiDZMl6PLqIDMaAv92EALw_wcB
Well there ya go! Thanks.
ODRedwine 1.51
Remember, unless your filters rotate with your camera you will need new flats for each orientation.
Rich-sky
David Redwine:
ouch!
may be easier to rotate the image during processing instead of the camera.
Gustav 1.20
For artistic composing and also to fit elongated objects into FOV, I would recommend a rotator. My TS 65 QUAD luckily have one integrated with the focuser.
matthew.maclean 3.97
The only caution I have found is that I have the WO rotator and it is quite thick. I discovered when I tried attaching the field flattener to it that the telescope could no longer reach focus on a DSLR because of all the extra length the rotator added. I think WO should have thought that combination through a bit better. The one David noted above looks much better because it is so thin.
