Cookie consent
I agree
Homemade RGB filters
matt113d
03 Sep, 2019 10:44
I recently bought a ZWO asi178mm camera with a view to eventually purchasing some RGB filters to produce colour images but also give me freedom to select my own bands for imaging. Not long after it arrived I decided I wanted colour images now. Without the money to buy them straight away, I was curious how well homemade filters would perform.
I coloured in some glass microscope cover slips with red, blue and green Staedtler permanent markers and characterised each of their spectral transmissions using a spectrometer I have access to at work. The results speak for themselves. I haven't had chance to take any images yet to test their practical effectiveness but I will provide an update when I have.
I will provide a graph below. The green is not as good as I'd hoped so I will be testing some other inks but I wanted to use a brand that people could easily access to try this for themselves. Please let me know if you have tried this or seen someone else try this. I have searched but I haven't found any post online detailing an attempt to produce homemade RGB filters.
Soundologist
03 Sep, 2019 21:14
Awesome experiment, Matt! I can't wait to see how it goes!
astropical
04 Sep, 2019 01:23
Hi Matt,
With permanent markers – amazing!
Green is near 100% in the ASI178MC specs :-)
Anyway, how would you rate the performance of your ASI178MM (in monochrome) as compared with a crop sensor DSLR when aiming at DSOs?
Cheers
Robert
whwang
04 Sep, 2019 02:59
It’s great that you are doing this experiment. Do show us the results.
Just by looking at the curves, I would suggest to pay attention to two things. First is the transmission above 700nm. The leakage of very-near-infrared light may have some (or huge) impact to the image quality or color saturation or color balance. The second one is that the overlaps among the three curves are much larger than that for typical astronomical RGB filters, and perhaps even somewhat larger than the RGB Bayer filters in DSLRs. This may substantially lower the color saturation. It can be fixed in post-processing though.
Wei-Hao
matt113d
04 Sep, 2019 08:37
Thanks for the responses.
The overlap/colour balance issue doesn't bother me too much. As you say, it can be corrected in post-processing. Really the point here is to produce colour images with a mono-sensor as cheaply as possible. I'm going to characterise some other green inks as clearly it's the weak link. As I stated before, it is important to me to use pens that could easily be identified and sourced by other people.
The NIR issue is definitely more pressing. I am currently looking for a cheap material with which to coat the glass that will produce the short-pass filter required. Though, again, the colour balance will be tricky to fix with the NIR in the mix, but not impossible. I could be wrong but I would imagine that the image quality loss would only really be a factor in refracting telescopes (because of chromatic aberration)? So reflectors would be okay. It might be possible to remove the NIR SP filter from an old camera but this is not really in the spirit of DIY in my opinion.
The main practical issue as I see it is coating the glass uniformly and without introducing scattering. Flat corrections will remove non-uniformity in the coating but scattering is a real issue. I think this merits the greatest challenge.
altazastro
04 Sep, 2019 09:59
astropical
Hi Matt,With permanent markers – amazing!
Cheers
Robert
I can answer to this one: when compared with an unmodified Canon EOS1300D, which has a 37% peak Q.E., it is literally another league: much more sensitive.
To give an idea, the Rosette Nebula imaged with a 100 mm refractor and the DSLR for 75 minutes gives more or less the same results of 45 minutes with the 178MM paired to a Tamron 135 F2.8 (which as approximately a 48 mm aperture).
Also the monochrome sensor facilitates processing in my opinion, and the absence of a Bayer mask in front of it improves resolution.
Since I bought the 178MM, I'm using the DSLR almost only when its much larger sensor is needed for width of field reasons.
Edited 04 Sep, 2019 09:59
astropical
04 Sep, 2019 11:29
Thanks very much for your view, altazastro,
I just saw your images. Amazing - with a 90mm MAK, ASI178MM and on an AZ-GTi!!!
I think the key is to choose a monochrome camera for sensitivity. The ASI174MM seems to be a good choice for lunar work as well.
So many images uploaded, when do you sleep?
Cheers
Robert
whwang
04 Sep, 2019 12:29
matt113d
Most reflective scopes for astrophotography still contains refractive elements, either as field flattener, reducer, or coma corrector.
You may want to take a look at this image of mine:
http://www.astrobin.com/189410/0/?image_list_page=3&nc=
You can click it to see the larger version.  The purple star is caused by a very small near-IR leakage in the filter.  It's so small that most of the stars look just normal.  However, on this star it becomes apparent because that star is super bright in the infrared, even brighter than Vega.  The scope is a reflector, with refractive corrector lenses.  Either the coating or the chromatic aberration correction in the refractive elements are not so optimized for the near-IR.  So when there is infrared light coming in, the image quality becomes very poor.  This is a combination of a small IR leakage and a very bright IR star.  Now imagine if the IR leakage is larger and this happens on every regular stars.
HR_Maurer
15 Sep, 2019 10:33
Hi Matt,
i know from experience, permanent marker strokes usually are several µm thick. Depending on your painting technique, this could introduce some distortion like anisotropic stay light and more. Did you already look at airy discs produced with these filters?
CS Horst
