Cookie consent
I agree
Lens Collar for Samyang / Rokinon 135mm F2.0 ED
jupiteriancoffee
22 Feb, 2018 16:38
Hello everyone,
I would like to know if any of you have a collar compatible with Samyang / Rokinon 135mm F2.0 ED.
The point is, my camera is a Sony A6000 which has a lightweight build and attaching the setup to the mount through camera gives too much tension to the lens mount on the camera. For now I am interchanging the rings of my finder scope but having a dedicated collar for the lens would be better.
Thanks for your help.
Thirteen
22 Feb, 2018 17:54
I was able to purchase a cheap off brand version of the collar that fits the canon 70-300L.
If the link works…
DSLRKIT Tripod Collar Mount Ring C (WII) for Canon 70-300mm f/4-5.6L https://www.amazon.com/dp/B0077XIY06/ref=cm_sw_r_cp_api_rnWJAbQSYNMZX
This will fit perfectly around the front of the lens near the hood.     That said, I have been able to completely manage the tilt so far.   It’s a beast to control.
jupiteriancoffee
22 Feb, 2018 18:07
Jason Guenzel
I was able to purchase a cheap off brand version of the collar that fits the canon 70-300L.If the link works…
Thank you Jason,
I am confused a little bit, are you using this collar on Samyang 135mm mounting on the front side of the lens?
Thirteen
22 Feb, 2018 18:14
Yes, I attach the camera (DSLR in this case) to a dovetail bar and support the front of the lens with this collar and attach it to the same bar.  I have a mismatch in height between the two mounting surfaces, so I shim them appropriately, but it may be that this is a source of my problem.   I may be applying some force to the camera/ lens interface.
One good option would be to do what some here are doing an d 3D print a two point attachment for the lens and let the camera only hang off the back.
Anyway it’s a problem for everyone and takes some work to properly square up the sensor to the lens.   I can confirm that the tripod collar I linked to above does fit the front of the lens barrel.    But I’m following this for other ideas!
good luck.
iamsiggi
22 Feb, 2018 22:59
Perhaps you found something by Andreas Dietz here at AB:
https://www.astrobin.com/users/dakloifarwa/
Siegfried
Edited 22 Feb, 2018 22:59
jupiteriancoffee
23 Feb, 2018 02:08
Jason Guenzel
Yes, I attach the camera (DSLR in this case) to a dovetail bar and support the front of the lens with this collar and attach it to the same bar.  I have a mismatch in height between the two mounting surfaces, so I shim them appropriately, but it may be that this is a source of my problem.   I may be applying some force to the camera/ lens interface.One good option would be to do what some here are doing an d 3D print a two point attachment for the lens and let the camera only hang off the back.
good luck.
I see, thank you for sharing your experience Jason.
In my humble opinion, letting the device hanging on the back while attaching the lens only is the way to go. For now that's the way I do it and so far so good except being have to switch between the lens and guide scope depending which kit I'll use on next AP session.
Regards!
jupiteriancoffee
23 Feb, 2018 02:10
Siegfried
Perhaps you found something by Andreas Dietz here at AB:https://www.astrobin.com/users/dakloifarwa/
Siegfried
Wow! This the way to go! Thank you for sharing this awesome project Siegfried!
Thirteen
23 Feb, 2018 02:11
I agree.   I am actually looking for a second collar that would work to fit the base of the lens barrel.  These collars are fairly cost effective.   Obviously if you have easy access to a 3D printer, the solution above looks like a good one.
jupiteriancoffee
23 Feb, 2018 02:28
Jason Guenzel
There are a few shops here I can have it printed. If the price is higher than the store of designer, I'll buy it from him I guess.
jupiteriancoffee
26 Feb, 2018 19:21
Hi everyone,
Due to logistics problems the 3d printed collar was not a possible choice for me however I bought something else and I believe this item deserves your attention as well.
https://www.aliexpress.com/item/Andoer-L200-Telephoto-Lens-Support-Long-Lens-Holder-Bracket-Compatible-for-Arca-Swiss-Sunwayfoto-RRS-Benro/32823937010.html
This item is an all-round cheap + versatile one.
Kind regards!
David_M
17 Apr, 2018 23:54
For the E mount version, you can try the Novoflex ASTAT-nex tripod collar.
A bit expensive, but very efficient!
Have a look here : https://www.astrobin.com/295430/?nc=user
smile
jupiteriancoffee
20 Apr, 2018 17:45
David
For the E mount version, you can try the Novoflex ASTAT-nex tripod collar.A bit expensive, but very efficient!
smile
Hi David,
Yes, I am well aware of this contraption and it's cost smile Thanks but no thanks.
Optikus64
21 Apr, 2018 18:17
Burak Mehmet Gurbuz
Hello everyone,I would like to know if any of you have a collar compatible with Samyang / Rokinon 135mm F2.0 ED.
-> https://www.dakloifarwa.com/products/astroschelle/
Kind regards
Jörg
