What guiding software do you use? | |
1) Metaguide | |
2) PHD2 | |
3) Other (pls. post with your preference) | |
I use the Ekos guider and it works better for me. Calibration seems to be more flexible and faster, the interface is more straightforward, and I think I get better results.
Which Feature is in metaguide that is not in phd2? In phd2 i use zfilter Algorithm, that is an Virtual exposeure time and avarage the seeing. in dec with poor polar alighment you can fight the backlash on older mounts. sometimes i reach an 0.5 rms total with oag on my 20 years old eq6. I put an Heavy 8 inch f6 newtonian at the mount |
I used to switch between PHD2 and the Ekos internal guider, and with the same settings for calibration and guiding parameters, same results in guiding. Or I should say I got similarly bad results with my strainwafe mount (WD17). Just dreadful amounts of periodic error. Had many occasions where PHD2 PPEC was not able to lock into the major period of the RA oscillation, so ended up with a good starting value from PHD2 frequency analysis, used this as a starting point in Ekos GPG, and used the resulting period in PHD2 without adaption. Then after the last KStars update, which changed the way Ekos calculates the RMS error so it’s in line with the way PHD2 calculates it, same results still. Until I accidentally deleted my equipment profile, and had to make a new one from scratch, haven’t seen guiding deviations above 0.4” since. Cannot find what changed. More on topic, is the use of single guide star, single guide star with lucky imaging or multi star. With a low powered mini PC, and a SW mount that needs frequent correction, multi star guiding is notably slower. Depending on seeing conditions I got the best results with either single star with frequent corrections, or multi star with only 5 stars and a 50% lower correction frequency. I assume single star with lucky imaging could give the same results as multi star, as long as the algorithm is fast enough. But there’s no way to use lucky imaging in guiding on Linux yet. Would be interesting to try out. Last five night, and probably the next five nights as well, seeing has been good, even excellent for my location. So I’ll stick with single star guiding since it gives me good results right now. |
John Wells: Thanks for replying as I was unaware of the Ekos guide module existed and would not have looked for it. I haven't field tested my Pi with all the new software and installed phd2 on it. From the webpage the Ekos module has an impressive, well thought out interface. I'm impressed with Kstars/Ekos enough that I put an nvme hat and drive on my Pi to get serious about imaging with it. |
Jochen Schambach:Tobiasz:Himanshu Pandey: * Hi, sorry for the late response. To be honest I do not know what the zfilter is or how it works, so I need an explanation here. The algorithm part in MetaGuide is only the calculation of the centroid. It uses a stacked & aligned image and searches the "hot spot"(=brightest part) of your guide star. This way most of the seeing/abberation induced deformations in the outer parts of the stars can be ignored (because they are not bright enough) and you are guiding on the "real" star core. You have direct control how the guide star is "presented" to the algorithm via the gain, exposure time, "stack time" and focus. The last session my seeing was between 1.8-2.5", but the "AFWHM"(= [Stacked &] Aligned full width half maximum) of my guide star was between 1.2-1.6". This makes your guidestar pretty pinpoint and it enables tight guiding. Guide settings are up to you. With the video view you can "live" test your guide settings and can change them instantly without affecting the calibration and without a "learning phase" of the tool. Guide period, guide rate, aggression are settings known from other tools. In general, I would say the algorithm is only one part of the equation and knowing your mount is the other. sometimes I have Great Results in dec with Pool polar aligment to fight backlash In Metaguide you can manually slew your mount by small amounts and find out your backlash value and type it in the backlash compensation field in the settings. Everytime your mount changes directions the exact amount of backlash comp. in milliseconds will be applied to the guide pulse. Because of the live view slewing around to find out your backlash is a pretty quick process. Frank did a presentation of Metaguide on the Astro Imaging Channel a few years ago. There he also explains the guiding part and how it works: Youtube Hope this helped a bit! CS Tobi |
