Skywatcher HEQ-5 ASCOM driver glitch Generic equipment discussions · Adel Kildeev · ... · 3 · 268 · 0
Starminer68 2.41
I recently experienced strange ASCOM driver glitch-ASCOM platform could not have se Skywatcher driver. I uploaded the latest version of the platform, then Skywatcher ASCOM driver- no changes. I am getting either message that the upload of driver is not possible (errors) or the driver shows no COM ports.... Any of ideas?
Lordsul 0.00
Hi
I also had the "no COM port error" with HEQ5 eqmod. Sometimes it could find port and perform well until randomly the same error happened and my whole session got ruined.
I bought a 6 usbhub and connected each of the cables to the same usb socket of the hub. And the hub to pc from the same usb socket of the pc. After that Im having no issues of same kind.
Of course i dont known if its the same kind of error and if this will work for you but COM port confusions are really a pain in the... 8)
Clear skies
sky-watcher 3.01
Hi Adel, a few weeks ago I experienced the same issue like you. I figured out that my cable (USB-HEQ5 Direct Interface) was damaged.I bought a Bluetooth interface, for Skywatcher mounts https://teleskop-austria.at/EQ5BUmi_EQ5pro-GoTo---BlueTooth-Einheit-fur-GoTo-und-Autoguider#m
and this worked prompt and works well.
 In any case I would try to replace the interface cable.
cs johny
Starminer68 2.41
Thanks, my friends, for your advices, I really appreciate your help. I like idea of the hub or Wifi adaptor, avoiding cables is a really good idea.
I did spend few hours with friend of mine, Software Analyst, we were able to download the ASCOM driver for Skywatcher. But the ASCOM platform still does not see any COM ports. I checked both cables between camera, notebook and the mount, looks fine. I replaced auto-guider camera with ASI 290 - the same problem, the camera works but no connection to the mount. Either the auto-guider port is broken or most likely I have serious problems with my notebook preventing proper work of the ASCOM platform and drivers. Next week I will run several tests to fix it. Meanwhile I was able to connect the notebook to the mount via the second USB-RC11 cable jack in the hand set, works fine.
