Cookie consent
I agree
TS-Optics 12" f/4 UNC Newtonian Telescope with Quartz main Mirror and Carbon Tube
fornaxtwo
08 Oct, 2018 12:41
Hello,
https://www.teleskop-express.de/shop/product_info.php/info/p5064_TS-Optics-12--f-4-UNC-Newtonian-Telescope-with-Quartz-main-Mirror-and-Carbon-Tube.html
Has anyone experience of one of these telescopes or similar? Are they good quality optically? Also any alternatives?
I will use primarily for imaging so would include a coma corrector, I have an EQ8 mount.
Many thanks,
Rob
Arringar
12 Oct, 2018 22:05
I would suggest looking into something a little smaller and of better quality. TS makes the ONTC Newtonians that are better designed for imaging. Also in the same category would be the Lacerta Photonewton which I personally think are slightly better and come equipped with an excellent focuser.
Edited 13 Oct, 2018 02:55
MDK
13 Oct, 2018 09:13
Hi
After many discution with many shop and TS about UNC, i have buying a ONTC by TS.
The fixation of primary miror it isn’t a good quality on UNC. And it’s impossible to change this piece before to buy.
i just trying in observation my ONTC and ir’s very nice. I think i will re-works the primary miror by a specialist but it’s nice.
if you can, buy a ONTC. It’s easy to move primary miror to use a ASA reducer and coma like evolution.
i hope i can help you (and sorry for my english smile
See ya
fornaxtwo
14 Oct, 2018 12:14
Thank you both for the very helpful comments. The 305mm ONTC may be a little out of my price range so maybe I'll consider the 250mm ONTC.
Thanks,
Rob
Arringar
15 Oct, 2018 03:24
Rob Johnson
Thank you both for the very helpful comments. The 305mm ONTC may be a little out of my price range so maybe I'll consider the 250mm ONTC.Thanks,
Rob
Consider the image pixel scale in combination with your camera. What camera will you be using?
fornaxtwo
15 Oct, 2018 20:05
I currently use a 14" f5.2 reflector with an Atik 383l+ binned 2x2 which gives me a scale of 1.17"/pixel. The 14" is just too heavy for the EQ8 with a long tube, I can get up to 20min subs but that's only on a steady night. I wanted a scope that was a shorter tube but still with a reasonable fl for visual use, after 35 years with  a 14" its a hard decsion to swop to a smaller telescope ☺
The 12" f4 would give 1.85 "/pixel which should still be ok I think?
Thanks,,
Rob
Edited 23 Nov, 2018 21:20
