Possible Kuiper belt object close enough for surface detail observations. [Solar System] Acquisition techniques · David Healy · ... · 69 · 3248 · 0
Ckuoidfs890 0.00
Merry Christmas!
I am a novice astrophotographer and just joined Astrobin.  I have been tracing a possible Kuiper belt object since Nov. 20.  I initially thought it was in the outer solar system, but angular diameter observations show it was
between Venus’ orbit and Mercury’s orbit for Thanksgiving.  Current angular diameter is on par with a distant Mars.  It is definitely not a comet as it sometimes produces a temporary coma.  I had planned to map this object before my announcement, but the weather has
cancelled that plan.  The bad weather did have one benefit.  I learned enough of the MPC format to let you have your turn at it.
    KBO    2016 11 30.03333 18 42 45.20 -25 40 09.0                      XXX
    KBO     2016 12 01.01325 18 41 41.70 -25 4628.0                      XXX
    KBO     2016 12 02.03220 18 42 04.50 -26 1203.0                      XXX
    KBO     2016 12 12.14667 20 08 48.00 -27 1650.0                      XXX
    KBO     2016 12 14.04056 21 02 21.10 -26 0136.0                      XXX
I have given you my five latest observations.  I don’t have a MPC code, so use the closest736.  All observations and GPS are available upon request.  Target is very dark so wait ten minutes after sundown before seeing it.  It is red in my finderscope.  It was too windy for barlows, but I made do with 299ms and 9.721 db gain.  Do you have any advice for imaging Kuiper belt objects this close?
As a New Year’s gift I am throwing this possible Earth impacter in.  Enjoy!
   2016 11 25.01747 18 25 58.50 -27 19 22.009.0 XXX
  2016 11 22.03064 18 13 36.10 -24 23 15.00 9.0XXX
  2016 11 24.04514 18 26 00.00 -24 03 10.00 9.0XXX
KuriousGeorge 1.20
Cloudy here but wish I could confirm your observations! Hopefully someone else can.
patrickgilliland 0.00
Same here but sounds like an interesting hunt awaits.
Weather aside would have no idea how to find myself but hopefully some expertise is here that can help.
Ckuoidfs890 0.00
I have uploaded two images of the object.  Here is the latest coordinate.
KBO            2016 12 16.03737 08 22.80 -24 52 18.00
Chunyu 0.00
Very interesting! Can you explain the MPC format or provide a link? Thanks!
Ckuoidfs890 0.00
The MPC Format refers to the minor planet center’s format.  You can use the information I have provided to calculate the orbit.  My early attempts ended with failure, so I am waiting for more information before
I make another attempt.  All I ask to go to the last set of coordinates I have provided and scroll down to the
horizon.  See for yourself if I am lying.
Ckuoidfs890 0.00
KBO          2016 12 18.01987 21 03 26.80 -24 08 49.00
Ckuoidfs890 0.00
KBO 2016 12 19.03531 21 02 43.20 -24 22 04.00
Odair.P.Martins 0.00
David,     20h 24m 33.8517s,   -21° 49' 02.092"  are coordinate of comet 45P/Honda-Mrkos-Pajdusakova with magnitude 8.71. This is the more closest  detectably object today in region.
Ckuoidfs890 0.00
2016 12 20.04676 20 40 57.00 -23 29 36.00
I thank you for the comet 45P/Honda-Mrkos-Pajdusakovasuggestion.  Comets don’t have moons, andthis one has several.  That is how I knowit is not a comet.  Would you like themoons’ coordinates so you could calculate their orbits?
wanni60 2.41
How about a new image?
If you can detect several moons, there should be a star background visible as well.
Not so much time left : according to your data, the object is coming back in RA.
Good luck !
Wanni
P.S. Constant bad weather at my place since weeks.
Otherwise I would try it myself, although I am highly sceptical about your find.
I wonder why nobody else could verfiy your observation, nothing heard from professional observatories yet.
Did you try to contact them?
Ckuoidfs890 0.00
After thinking about it, the target might be producing a coma.  When it does it you see what looks like a line of comets in your telescope.  Since the moons are somewhat spaced out now you would have to move it around.  So if you are interested in seeing comets, try looking at this object tonight.
whwang 11.57
Wanni:
I wonder why nobody else could verfiy your observation, nothing heard from professional observatories yet.Did you try to contact them?
Kuiper belt objects with several moons and apparently as large as Mars..... Highly unlikely.  Google or check wiki to see what the largest few Kuipter belt objects are like.  Even Pluto does not come close to this description.
Odair Pimentel Martins:
Please, take a picture with background stars  for astrograph solution.  ;)
Odair
wanni60 2.41
Wei-Hao Wang:
Wanni:
I know, I imaged Pluto several times, which was quite a challenge.
Only by overlaying two images a day apart, I could verfiy Pluto by it's movement relativ to the background stars.
(see at my page)
But obviously David is tracking something. I took all his data and made a plot over RA/DE.
The path looks consistant, but what it is, we don't know.
So either he is seeing really something or it is a complete hoax.
8)
Wanni
MikeP 0.00
Someone has come back from the grave: David Healy   (what an amazing man!)
Ckuoidfs890 0.00
2016 12 21.04755 20 47 09.00 -25 25 33.00
Thanks Wanni.  You don’t know what this means for me.  I shot the target with my deep sky camera.  There has been a reason I have not been honest with you about what I am seeing.  I now submit evidence showing the target is more the size of Earth than Mars.  To do this you need to download my image and blow it up to 400%.  Clearly the tails are ionized or they would be pointing directly behind the sun.  You will see a bow shock.
whwang 11.57
sounds like a comet.
nekitmm 2.41
I computed its trajectory and looks like it's headed straight towards Earth!
wanni60 2.41
Here a list of current observable comets :
http://www.aerith.net/comet/weekly/current.html
Ckuoidfs890 0.00
The weather hasn't been helpful with taking photos.  I am likely out till the New Year.  If you do seek this object out my only advice is expect the unexpected.  It is quite a variable magnitude object.  I have seen it as a comet like object so bright I thought it would be visible to the naked eye to so dim I was surprised it showed up in my finding scope.  It will show up as a red object or as a bright comet like object your finder scope.  If you do seek this object, please reply so I see if I lived up to your expectations.
Ckuoidfs890 0.00
What a great Christmas gift.  Too windy for pictures, but here is the latest coordinate.  2016 12 26.02257 20 15 39.90 -18 53 46.0
MikeP 0.00
Merry Christmas?!
Ckuoidfs890 0.00
Good news.  My cloudy nights have been far from in vain.  I was unable to use my location to calculate the orbit.  I had to use Houston as the location.  There are multiple orbits that fit my data soI won’t publish the details, with one exception.  The target will be make its’ closest approach in May.  I can’t see all the uncertainties putting the target out your finder scope’s range by then, so I will publish the
geocentric coordinates so you can see it. The target will be either a bright star or a more likely red object in your finderscope.
#Geocentric
Date (UTC)   RA              Dec         delta  r     elong
2016 12 28  22 5731.662   -09 14 46.35  .92203 1.0340 65.6
2016 12 29  23 0037.793   -08 49 09.72  .92192 1.0319 65.5
2016 12 30  23 0344.091   -08 23 23.75  .92177 1.0297 65.3
2016 12 31  23 0650.570   -07 57 28.64  .92156 1.0276 65.2
2017 01 01  23 0957.245   -07 31 24.62  .92131 1.0255 65.1
2017 01 02  23 1304.130   -07 05 11.90  .92100 1.0234 64.9
2017 01 03  23 1611.237   -06 38 50.73  .92065 1.0213 64.8
2017 01 04  23 1918.581   -06 12 21.33  .92025 1.0192 64.6
2017 01 05  23 2226.175   -05 45 43.94  .91980 1.0172 64.5
2017 01 06  23 2534.032   -05 18 58.83  .91930 1.0151 64.4
2017 01 07  23 2842.168   -04 52 06.24  .91876 1.0131 64.3
2017 01 08  23 3150.595   -04 25 06.43  .91816 1.0111 64.1
2017 01 09  23 3459.330   -03 57 59.66  .91753 1.0091 64.0
2017 01 10  23 3808.390   -03 30 46.20  .91684 1.0071 63.9
2017 01 11  23 4117.794   -03 03 26.30  .91612 1.0052 63.8
2017 01 12  23 4427.562   -02 36 00.24  .91534 1.0033 63.7
2017 01 13  23 4737.717   -02 08 28.26  .91453 1.0013 63.6
2017 01 14  23 5048.284   -01 40 50.62  .91368 0.9995 63.5
2017 01 15  23 5359.287   -01 13 07.60  .91278 0.9976 63.3
2017 01 16  23 5710.753   -00 45 19.44  .91184 0.9957 63.2
2017 01 17  00 0022.710   -00 17 26.43  .91086 0.9939 63.1
2017 01 18  00 0335.184   +00 10 31.17  .90985 0.9921 63.0
2017 01 19  00 0648.202   +00 38 33.08  .90879 0.9904 63.0
2017 01 20  00 1001.793   +01 06 39.00  .90770 .98862 62.9
2017 01 21  00 1315.983   +01 34 48.65  .90657 .98691 62.8
2017 01 22  00 1630.800   +02 03 01.70  .90541 .98522 62.7
2017 01 23  00 1946.271   +02 31 17.86  .90420 .98355 62.6
2017 01 24  00 2302.423   +02 59 36.79  .90296 .98192 62.5
2017 01 25  00 2619.284   +03 27 58.17  .90169 .98032 62.4
2017 01 26  00 2936.880   +03 56 21.66  .90038 .97874 62.4
2017 01 27  00 3255.238   +04 24 46.91  .89904 .97720 62.3
2017 01 28  00 3614.385   +04 53 13.56  .89766 .97568 62.2
2017 01 29  00 3934.347   +05 21 41.24  .89625 .97420 62.2
2017 01 30  00 4255.148   +05 50 09.56  .89480 .97275 62.1
2017 01 31  00 4616.815   +06 18 38.13  .89332 .97133 62.0
Ckuoidfs890 0.00
2017 02 01  00 49 39.371   +06 47 06.54  .89182 .96995  62.0
2017 02 02  00 53 02.840   +07 15 34.36  .89028 .96860  61.9
2017 02 03  00 56 27.247   +07 44 01.17  .88871 .96728  61.9
2017 02 04  00 59 52.614   +08 12 26.51  .88711 .96600  61.8
2017 02 05  01 03 18.968   +08 40 49.94  .88548 .96476  61.8
2017 02 06  01 06 46.332   +09 09 10.99  .88382 .96355  61.7
2017 02 07  01 10 14.733   +09 37 29.17  .88214 .96238  61.7
2017 02 08  01 13 44.198   +10 05 44.03  .88043 .96125  61.7
2017 02 09  01 17 14.755   +10 33 55.07  .87870 .96015  61.6
2017 02 10  01 20 46.436   +11 02 01.79  .87695 .95909  61.6
2017 02 11  01 24 19.271   +11 30 03.72  .87518 .95807  61.6
2017 02 12  01 27 53.294   +11 58 00.34  .87338 .95709  61.6
2017 02 13  01 31 28.539   +12 25 51.16  .87157 .95615  61.5
2017 02 14  01 35 05.041   +12 53 35.67  .86974 .95525  61.5
2017 02 15  01 38 42.833   +13 21 13.34  .86790 .95440  61.5
2017 02 16  01 42 21.951   +13 48 43.65  .86604 .95358  61.5
2017 02 17  01 46 02.431   +14 16 06.05  .86416 .95280  61.5
2017 02 18  01 49 44.305   +14 43 20.00  .86227 .95207  61.5
2017 02 19  01 53 27.609   +15 10 24.93  .86037 .95137  61.5
2017 02 20  01 57 12.376   +15 37 20.27  .85846 .95072  61.5
2017 02 21  02 00 58.639   +16 04 05.43  .85654 .95011  61.5
2017 02 22  02 04 46.430   +16 30 39.81  .85461 .94955  61.5
2017 02 23  02 08 35.782   +16 57 02.81  .85268 .94903  61.5
2017 02 24  02 12 26.725   +17 23 13.79  .85073 .94855  61.5
2017 02 25  02 16 19.288   +17 49 12.13  .84878 .94811  61.5
2017 02 26  02 20 13.500   +18 14 57.17  .84682 .94772  61.5
2017 02 27  02 24 09.387   +18 40 28.25  .84486 .94738  61.6
2017 02 28  02 28 06.973   +19 05 44.69  .84290 .94708  61.6
2017 03 01  02 32 06.281   +19 30 45.79  .84093 .94682  61.6
2017 03 02  02 36 07.330   +19 55 30.84  .83896 .94661  61.6
2017 03 03  02 40 10.139   +20 19 59.10  .83699 .94644  61.7
2017 03 04  02 44 14.724   +20 44 09.84  .83502 .94631  61.7
2017 03 05  02 48 21.100   +21 08 02.29  .83305 .94624  61.7
2017 03 06  02 52 29.281   +21 31 35.68  .83109 .94620  61.8
2017 03 07  02 56 39.279   +21 54 49.25  .82913 .94621  61.8
2017 03 08  03 00 51.106   +22 17 42.19  .82717 .94627  61.9
2017 03 09  03 05 04.775   +22 40 13.73  .82522 .94637  61.9
2017 03 10  03 09 20.295   +23 02 23.05  .82329 .94652  62.0
2017 03 11  03 13 37.676   +23 24 09.37  .82136 .94671  62.0
2017 03 12  03 17 56.929   +23 45 31.89  .81944 .94694  62.1
2017 03 13  03 22 18.060   +24 06 29.80  .81754 .94722  62.2
2017 03 14  03 26 41.077   +24 27 02.29  .81565 .94755  62.2
2017 03 15  03 31 05.984   +24 47 08.58  .81378 .94792  62.3
2017 03 16  03 35 32.783   +25 06 47.84  .81193 .94833  62.4
2017 03 17  03 40 01.475   +25 25 59.29  .81010 .94879  62.4
2017 03 18  03 44 32.057   +25 44 42.11  .80829 .94929  62.5
2017 03 19  03 49 04.524   +26 02 55.51  .80649 .94983  62.6
2017 03 20  03 53 38.865   +26 20 38.70  .80473 .95042  62.7
2017 03 21  03 58 15.070   +26 37 50.87  .80298 .95105  62.7
2017 03 22  04 02 53.124   +26 54 31.23  .80127 .95172  62.8
2017 03 23  04 07 33.006   +27 10 39.02  .79958 .95243  62.9
2017 03 24  04 12 14.694   +27 26 13.45  .79791 .95319  63.0
2017 03 25  04 16 58.162   +27 41 13.75  .79628 .95399  63.1
2017 03 26  04 21 43.378   +27 55 39.19  .79467 .95483  63.2
2017 03 27  04 26 30.308   +28 09 29.01  .79310 .95571  63.3
2017 03 28  04 31 18.909   +28 22 42.49  .79156 .95663  63.4
2017 03 29  04 36 09.135   +28 35 18.92  .79004 .95759  63.5
2017 03 30  04 41 00.935   +28 47 17.60  .78857 .95859  63.6
2017 03 31  04 45 54.252   +28 58 37.84  .78712 .95963  63.7
2017 04 01  04 50 49.022   +29 09 18.99  .78572 .96071  63.8
2017 04 02  04 55 45.179   +29 19 20.38  .78434 .96182  63.9
2017 04 03  05 00 42.653   +29 28 41.41  .78301 .96297  64.0
2017 04 04  05 05 41.368   +29 37 21.48  .78171 .96416  64.2
2017 04 05  05 10 41.250   +29 45 20.01  .78046 .96539  64.3
2017 04 06  05 15 42.218   +29 52 36.47  .77924 .96665  64.4
2017 04 07  05 20 44.192   +29 59 10.37  .77807 .96795  64.5
2017 04 08  05 25 47.090   +30 05 01.24  .77694 .96928  64.6
2017 04 09  05 30 50.826   +30 10 08.65  .77586 .97065  64.8
2017 04 10  05 35 55.315   +30 14 32.22  .77482 .97205  64.9
2017 04 11  05 41 00.470   +30 18 11.61  .77383 .97349  65.0
2017 04 12  05 46 06.203   +30 21 06.52  .77289 .97495  65.1
2017 04 13  05 51 12.423   +30 23 16.70  .77200 .97645  65.3
2017 04 14  05 56 19.041   +30 24 41.93  .77116 .97798  65.4
2017 04 15  06 01 25.964   +30 25 22.04  .77038 .97954  65.5
2017 04 16  06 06 33.100   +30 25 16.93  .76965 .98113  65.7
2017 04 17  06 11 40.357   +30 24 26.52  .76897 .98275  65.8
2017 04 18  06 16 47.641   +30 22 50.78  .76834 .98440  65.9
2017 04 19  06 21 54.859   +30 20 29.73  .76778 .98608  66.1
2017 04 20  06 27 01.919   +30 17 23.46  .76727 .98778  66.2
2017 04 21  06 32 08.727   +30 13 32.06  .76681 .98951  66.3
2017 04 22  06 37 15.193   +30 08 55.72  .76642 0.9913  66.5
2017 04 23  06 42 21.224   +30 03 34.64  .76609 0.9930  66.6
2017 04 24  06 47 26.732   +29 57 29.09  .76581 0.9949  66.7
2017 04 25  06 52 31.625   +29 50 39.37  .76560 0.9967  66.9
2017 04 26  06 57 35.815   +29 43 05.83  .76544 0.9985  67.0
2017 04 27  07 02 39.213   +29 34 48.89  .76535 1.0004  67.2
2017 04 28  07 07 41.728   +29 25 48.97  .76531 1.0023  67.3
2017 04 29  07 12 43.273   +29 16 06.58  .76534 1.0042  67.4
2017 04 30  07 17 43.760   +29 05 42.22  .76543 1.0062  67.6
2017 05 01  07 22 43.103   +28 54 36.47  .76558 1.0081  67.7
2017 05 02  07 27 41.222   +28 42 49.92  .76579 1.0101  67.9
2017 05 03  07 32 38.036   +28 30 23.19  .76607 1.0121  68.0
2017 05 04  07 37 33.472   +28 17 16.96  .76641 1.0141  68.1
2017 05 05  07 42 27.460   +28 03 31.90  .76681 1.0162  68.3
2017 05 06  07 47 19.936   +27 49 08.74  .76728 1.0182  68.4
2017 05 07  07 52 10.839   +27 34 08.24  .76781 1.0203  68.5
2017 05 08  07 57 00.115   +27 18 31.15  .76841 1.0224  68.7
2017 05 09  08 01 47.712   +27 02 18.28  .76907 1.0245  68.8
2017 05 10  08 06 33.585   +26 45 30.45  .76981 1.0266  69.0
2017 05 11  08 11 17.694   +26 28 08.48  .77061 1.0287  69.1
