Whats my best move in this case? | |
Custom Camera App | |
New eyepiece | |
Proper astrocamera instead of iPhone | |
Just get a bigger telescope | |
None of the above | |
0.90
1. It is probably too bright, so that the cloud belts are burned out. 2. There is some lateral color. This means: A: Jupiter was low in the sky/close to horizon so that you get atmospheric dispersion. or B: The iPhone lens is not up to the task. A dedicated cam, (like a modified webcam) is the best move IMO. It will make things so much easier. |
2.86
If the problem is in brightness, what could be done to reduce it? May adjusting camera settings like ISO fix it? |
1.20
3
Hello, I've previously captured images of Jupiter and Saturn using an 8" Dobsonian and an iPhone 12 mini. What I did was use a good phone adaptor (Celestron XYZ) and an iPhone app called "ProCamera. RAW Photo and Video". It allows you to control the focus and brightness (ISO) levels as well as saving the images as RAW. I know video is commonly used but unless its lossless, RAW seems to do just fine if not better My steps are: 1) Point to something like the moon or a lamplight to illuminate the eyepice 2) Adjust the phone with the XYZ adaptor until it fits perfectly onto the eyepiece 3) Point to the desired planet 4) Place the focus square and brightness circle in the center 5) Focus and adjust brightness 6) Start shooting raw frames and manually keeping the planet centered in the square triggered from (4) I suggest practicing in the following order of difficulty: Moon, Saturn then Jupiter. Looking forward to hearing your progress!! |
