Siril-1.4 is out Siril Team Siril · Cyril Richard · ... · 34 · 1630 · 2
OklahomAstro 5.08
Cyril Richard:
V:
@Cyril Richard is there any way to modify or change the QE graph for a camera in SPCC? I have an extended range QE graph available for the ASI2400MC that I'd like to use since my camera is not using a UV/IR cut window, but I'm limited to the UV/IR cut window's range.
It is possible to improve the data yes. Here is the way to provide new data: https://siril.readthedocs.io/en/latest/processing/color-calibration/spcc-database.html
In your case, you just have to modify the existing data and open a merge request.
Awesome, thank you!
Pariah 1.20
Merci beaucoup! I will download later today.
I hope everybody donates as a thank you. SIRIL is a great tool for the astro imager.
Are you able to do masking in 1.4? This is the tool I would love to see integrated into Siril..
sfanutti 1.91
@Cyril Richard  I have a small request. Please make future versions of Siril as backwards compatible as possible. My 2017 iMac won't upgrade beyond Ventura and I've already upgraded my machine as far as possible. An annoyance over the years is that some developers develop software for the latest and the greatest OS incompatible with recent previous versions. Not everyone can buy a new computer just because a software company has decided not to support older OS's anymore. Siril greatly improved my solar images. Without it, I would still be manually stacking images pixel by pixel like I did in my early years of this hobby a decade ago. I also have Siril installed on a Windows machine just in case you must drop support for Ventura.
astro_dom 0.00
Thank you.  Will I have to reinstall the pointers to my Starnet++ program or will it just update to 1.4 with the settings that I have already with v1.2?
lock042 16.46
Steven Fanutti:
I hear you, but it's not up to us. We're using part of an evolving macOS SDK. And unfortunately, that's what makes the minimum versions required evolve.
Use Linux, and you can keep using Siril almost forever .
sfanutti 1.91
So, I installed Kubuntu on VirtualBox. I have used Ubuntu for many years on and off. I found that installing on my iMac in the past worked, but some hardware wasn't supported such as the SD card and audio, but there are workaround solutions for that. This time around, I decided to install it on VirtualBox so that I can still use macOS as the base system and when Ventura is not supported anymore, use the Kubuntu installation for web browsing. Theoretically, I can continue to keep updated that way indefinitely. In practice, I will see.
I really like the Synaptic Package Manager. It makes software installation easy. I learned years ago to avoid manually editing files for configuration unless you really know what you are doing or you can break the system. So, Kubuntu on VirtualBox is my migration strategy. Unlike some company, I don't have a trillion dollars in the bank and I can't afford neverending upgrading hardware just because. In real life, most people don't have unlimited incomes.
gnnyman 5.08
After installing the new software, I wanted to use the script - OSC preprocessing without flats -----did not work, got the message with something like....not yet implemented...?
What now?
lock042 16.46
Georg N. Nyman:
What now?
This is because you use old scrips that are deprecated.
AstroÅmazer 0.00
Possible bug: When I try to run the StatisticalStretch.py script, I get a dialog saying ' "SirilInterface" object has no attribute "claim_thread" '. Here is the console log:
05:53:30: Starting script C:\Users\gauta\AppData\Local\siril-scripts\processing/Statistical_Stretch.py
05:53:33: Connecting to Windows pipe: \\.\pipe\596efd74-b619-4730-98be-c10ae24081ac
05:53:33: Running command: requires
05:53:33: OK! This script is compatible with this version of Siril.
05:53:52: Exception in Tkinter callback
05:53:52: Traceback (most recent call last):
05:53:52:   File "C:\Program Files\Siril\python\Lib\tkinter\__init__.py", line 1968, in __call__
05:53:52:     return self.func(*args)
05:53:52:            ^^^^^^^^^^^^^^^^
05:53:52:   File "C:\Users\******\AppData\Local\siril-scripts\processing/Statistical_Stretch.py", line 351, in apply_changes
05:53:52:     self.siril.release_thread()
05:53:52:     ^^^^^^^^^^^^^^^^^^^^^^^^^
05:53:52: AttributeError: 'SirilInterface' object has no attribute 'release_thread'. Did you mean: '_release_thread'?
Looks like the Siril python interface was updated but the scripts did not update. I have Automatic updates turned on. How do I fix this? This was working yesterday.
lock042 16.46
AstroÅmazer:
Just restart Siril.
