Is Anyone Using the WO Flat 61 R William Optics Flat61R · John Noble · ... · 4 · 286 · 0
JohnNoble 2.41
·  310 views
Tried to use my new Flat 61 R last night and couldn’t get to focus. I’m very familiar with the WO adjustable flatterers but just couldn’t get to focus.
Im using a ZWO ASI 2600 with filter wheel and OAG and have the adjustable flattened set to 1 mm as suggested. That gives the 56 mm back focus.
To reach focus I’d need to go negative on the focus tube - ie fully retracted still too far away!!!
I ended up switching back to my 61A which works fine at 31 mm of extension.
Im hoping I’ve just missed something!
I did switch out the rotator from the 61R with that from the 61A to get closer but still no deal.
Thanks
JohnNoble 2.41
·  184 views
Ok I fixed it for future reference the focused extension with the Flat 61 R is around 9 mm and the 61 A is 30 mm.
My filter wheel was clashing with the dove tail bar preventing me reaching the 9 mm - something that wasn’t obvious in the dark at 20 f.
Another classic it’s dark and I’m cold error!
XCalRocketMan 3.71
·  163 views
I'd be curious what you think of the Flat 61R.  I'm having some serious coma and star distortion with my ZS61 and ASI2600.  Contacted WO about a possible defect in the flattener.  They gave me some things to try and so I'm waiting for clear skies to try again.
JohnNoble 2.41
·  153 views
Michael
I was able to get the set up working tonight I used the 1 mm off set recommended by WO and the field looked OK. I have a bit of tilt in one corner but I think the flattener is working just fine.
Good luck with yours
XCalRocketMan 3.71
·  84 views
John,
After re-measuring everything and adding the ZWO Tilter to the mix I was finally able to get the Flat61R working.
