Focuser for RASA 11V2 Celestron RASA · Dave & Telescope · ... · 5 · 137 · 0
darkmatter3 2.41
Hi folks,
I'm setting up a RASA 11V2 and wondering what autofcusers are working for you. Thanks in advance for your input.
Dave
dmsummers 6.80
Hi Dave, I have the V1 RASA11 and a ZWO EAF.  There are about 100 motor steps covering the CFZ in seeing of 2.0 arcsecs (5% focus tolerance, NCFZ formula).     If NCFZ is new to you, you can google New Critical Focus Zone for the formula...    I find the EAF works great, even though there is some backlash when switching directions (about 85 counts).   I prefer to focus consistently inward to conclude a focus run to avoid that, but there are other options (like just adding a pre-offset count if you are switching directions).
CS  Doug S
https://app.astrobin.com/u/dmsummers
darkmatter3 2.41
Thanks Doug. So it looks like for the EAF you need to replace/ add on to the stock RASA focuser , a feathertouch somehow? Is that what you did?
dmsummers 6.80
yes, you need to remove the stock outer knob and then connect (via set screws) a spring like bushing to the focuser drawtube (tel side), and to the EAF motor shaft.   There's a bracket to hold the motor as well.   The procedure for this was straightforward enough (and there's instructional material that can be found on the web or in the EAF document).
Fegato 0.00
I have the Pegasus FocusCube Zero (for SCT) on my RASA 11 v2.  Works really well. Very similar to the EAF (I have one on another rig).  As above, there is a bit of backlash with the USFS. I use NINA and have "overshoot" set in the autofocus settings.
AstroDude 0.00
I have the Rasa 11 V2 and use the Celestron focus motor, works fine !
Miguel
