Crop settings for simulation on telescopious ZWO ASI585MC Pro · Javier · ... · 2 · 114 · 1
javieralso 0.00
I currently have a modded Nikon D5300 but I am considering getting a ZWO ASI585MC Pro. Before that, I'm doing some simulations on Telescopious to compare with my current one, but I'm not sure if I should set the crop factor to 1x or if I should increase it (as the ZWO has a sensor smaller than a "full-frame" camera).
What would be the right setting for this?
Thanks!!
Javier
andreatax 7.90
What cropping? None of the sort, you just enter the sensor info and you are set.
javieralso 0.00
Thanks @andrea tasselli
That's what I was suspecting, but I wasn't sure it would be the right setting. For my Nikon, apart from the sensor info, I also have to set up the cropping factor so I can have a very accurate simulation. If I leave the Cropping to 1x with that camera selected, the field of view on telescopious is larger than the actual one, hence my question.
Javier
