ZWO ASI 1600 and Canon camera lens Camera Lens Astrophotography · Michael C. Neitzel · ... · 8 · 381 · 0
Starchaser1945 0.00
I am curious if anyone has tried this combination and with what kind of results...
Thank you!
Michael
jrista 8.59
Michael, all of my recent work so far with the ASI1600MM-C has been with a Canon 600mm f/4 L II lens. You can check my ABin page.
Starchaser1945 0.00
Well, what a relief and good to hear. Will go pronto to take a look! Thank you!
Michael
Antonio.Spinoza 0.00
I've done a couple of images with a Canon 70-200mm telephoto and been pretty happy with the camera and lens combo:
http://www.astrobin.com/267681
http://www.astrobin.com/269313
Starchaser1945 0.00
Hello Antonio,
Wow! VERY impressive, also makes me happy that this indeed works. Thank you!
Michael
In case you don't already have an adapter for EOS lenses, there are two different adapters made by ZWO.  Which one you need depends on whether you have a filter wheel attached or not.
The adapter for attaching to the ZWO EFW  is only $38 and can be found here (https://astronomy-imaging-camera.com/products/accessories/eos-lens-adapter-efw-asi1600/)
However, if you are using the color model without a filter wheel, I think you can use the EOS-T2 Adapter with adjustable back focus.
The EOS Lens Adapter for the EFW appears to lock reasonably well, but mine actually has a little bit of wobble in it, so I've seen a couple of subs that appear to spontaneously shift in the middle of a session.  There is probably a way to rig it to be very tight, but I haven't had enough trouble with that to bother.  I don't know if others have noticed that the adapter does not lock as tightly as to an actual Canon camera, but it could also be just my individual instance of the adapter.
Jon, if you still see this thread, do you use the ZWO EOS adapter, and if so, does yours have a little bit of play in it?
Starchaser1945 0.00
Hi Antonio,
Thanks for the info. Sam sent we the adapter that fits all so to speak.
Take care and all the best!
Michael
Thanks.  You should be good to go.  Does it fit nice and tight?
wessel 7.16
Can somebody present the image treated by CCD Inspector showing how ASI 1600 works with the different kind of optics? I am afraid that with 3.7 um pixel its far from ideal...
