Do you have any idea what is correct?
I try to set the better space between primary and secondary to avoid curvature and I prefer start with the right numbers and save some tests.
Originally my trust telescope come with 1999.6 mm solved in astrometry.net without any flattener or anything.
After some collimation and iterations now is 2009.9 mm at same conditions than before.
Move 1 mm the secondary means to correct 10 mm on the focal length, I want to correct it but... to 2032 or 2000?
Also, I'm running out of backfocus to add a rotator, if our scope is designed for 2032 mm, add 3 cm of backfocus could be great to me.......
Another point is about the light entering in to the sensor because the baffle is smaller than required, maybe with 2032 this is improved too. (see this post)
At the end the curvature field will tell me what is correct, but as I said, I prefer not to do to many test and imaging after this horrible winter
any ideas will welcome
