1.51
This otherwise fine and popular scope's weakest link is its focuser, I think. After a lot of problems I decided to upgrade to a much better focuser from Baader Planetarium. I have documented the process in a video where I also show how you can align the focuser perfectly with the optical axis of the primary mirror. If you are interested you may find the video here: https://youtu.be/1logCewVcpI Best regards, Flemming |
1.20
Luckily I did see this problem before buying and managed to make vendor do the swap against the cost difference. I got the Teleskop-Express: TS-Optics 2,5" Zahntrieb Okularauszug mit M90x1 Anschluss und 360° Rotation . It allows me to place the flattener/reducer inside the focuser. I did not have to correct the direction of the focuser. I have a M90 tilt in front, but have not had to adjust it. |
1.51
Gustav Lundby: Yes, that is also an ok focuser. It is mechanically identical to the one I have on my 94mm EDPH refractor, and works fine. It does feel a little bit springy, though, and not quite as responsive as the Diamond Steeltrack. That's fair enough considering the price difference. |
Flemming Kristensen: That's the same one I got for my TPO RC6 and love it. |
