Question about the dew heater and dew shield Takahashi Epsilons · URmyArtemis · ... · 7 · 258 · 2
URmyArtemis 0.00
Hi, I would like to know if a dew shield for epsilon 160ED is necessary. I am still waiting the 160ED, it is in shipping. I will usually use it in PA Cherry Springs.
Sometimes it could be very humid in the night. I dont know if a dew shield will work or not. If it has to be a dew heater, will the heat have bad influence? Where do you usually attach the dew heater if you use it? At the bottom or near the top or somewhere in the middle? Thank you!
Clear Skies,
Dan
neverfox 2.97
I think it's a good idea but you need to be careful about how extended it is. AstroZap makes one but it's too long. However, if you contact them, they will do a custom one like this:
If also suggest getting their "shower cap" dust cover, so you don't need to take the shield off.
astrojoe 5.57
I have no personal experience with the 160, I own and use a 210 which is very old respect to the newer 130-160-180. I really never have had issues with humidity whithout any dew heater or light shield. If it was the case so the conditions where really useless for astrophotography at all. Anyway my tube is really big and the primary mirror is really inside the tube, also the secondary mirror is quite inside and the tube act as a light baffle. I don't know about Yours.
p088gll 2.15
Honestly I never had issues with dew with my E130, even though we do have humid nights. I ordered a dew shield together with the telescope, but I never used it. Thats maybe also because mine is long and really difficult (if not impossible) to attach.  I would order a dew shield only if it is shorter and specifically fitted for the Epsilon. I would use the dew shield not so much against dew, but as an additional protection against stray light shining into the tube.
Jlndfr 1.20
Roman Pearah:
Hi Roman,
i’m looking for a dew shield for my 160ed.
could you tell me the length of your custom ?
it’s shorter than this one ? https://astrozap.com/products/takahashi-epsilon?variant=8283305181228
julien
_Frank_ 3.91
Hi Julien,
I‘m also using your linked dew shield from Astrozap. It‘s perfectly fine for my Epsilon 130-D. No problems with vignetting or anything else - it‘s doing its job 👍
Frank
Jlndfr 1.20
Frank Breslawski:
Hi Julien,
Frank
Thanks a lot Frank.
Nice to read it !
i’ve lost 4 hours last night. And i don’t want to loose anymore photon :-)
_Frank_ 3.91
Julien Dufour:
Unfortunately this is also part of our hobby  Don't know how much hours of collected photons I also had to delete in the past...
