Now this is interesting https://www.youtube.com/watch?v=ezEeBnXronk Never heard anyone say this before. I don't know if you guys agree with him, but if you do it could save some time. As a total noob, I'll be interested to hear your views. |
6
His arguments are weak. Of course you shouldn't waste precious time under dark clear skies to take dark frames. They can be easily taken after imaging session while temperature is still within few degrees from light frames. Or different/cloudy night with the same ambient temperature (or just in the fridge ![]() So as long as you don't waste your imaging time and can match the temperature between light and dark frames - it's always better to make darks and calibrate lights with them. |
I often do not shoot dark frames, but it's mostly due to time and location constraints. I can't just set up at my home, so I have to go somewhere to shoot anything. Since I go at least a half hour from home, I end up doing lights and flats and just doing my best with it, especially when I am doing 3-5 minute exposures. However, anecdotally, when I am able to do a proper run of darks, I do notice a difference in my photos. |
I agree with Nadir Astro. I usually start my darks right after imaging, so at least an hour before dawn. I also don't have a permanent setup, so when I'm done imaging I bring the scope inside, but into an entryway I've left open to match outside ambient. In addition, I bag the scope in a heavy duty (i.e. thick and opaque) trash bag to further reduce light and moderate temp change. Not completely sure about temp though, the bag might also be trapping heat from the camera.... More importantly for me is that the darks take care of the infamous Canon banding I get with my 5D/IV, especially at particular ISO's. PI has a Canon de-banding script, but so far at least I'v only gotten it to trade gradients for banding. I can more easily take care of gradients during processing, but I'd rather not have to deal with either. Cheers, Scott |
Sorry...didn't mean to reply twice and don't see how to delete one. |
5
If these are his images, He should probably not only start taking dark frames. He could also benefit from better flats, and probably some dithering. Some DSLRs have built in noise reduction properties. Maybe that is what is helping with his hot pixel noise, maybe it is (poor mans) dithering. It also looks like he uses some heavy after stretch NR in some of his later images which will get rid of some noise. I would definitely test it yourself and see how your images turn out without darks (as he also proposes).![]() |
3
I've been using a DSLR for some time and it definitly helps to use darks frame. In my case (Nikon D5600) there is a big red/violet amp glow on the bottom of the images that dark frame really help remove, even if they are a few degrees off. |
For a DSLR, Darks, Flats and Bias are just sensible. All remove different types of noise or artifacts from images that already have very low levels of signal. Thus boosting your precious Signal to Noise Ratio. In the UK there are plenty of cloudy nights when you build up a temperature matched Dark Library to avoid wasting precious imaging time. |
Agree with all here. My Canon 6D is already pretty good at handling noise (w/o NR on, of course) but on those warmer nights (and as the camera ages, it seems) I develop more hot pixels and the need for darks is obvious. I have always used darks and will continue for noise and hot pixels sake, but I have dumped my bias frames as they have always complicated my stretching for some reason. And yes, building up dark libraries is huge!! |
4
I have always used darks and will continue for noise and hot pixels sake, but I have dumped my bias frames as they have always complicated my stretching for some reason. Bias frames are valid only for CCD sensors and are meaningless and even detrimental for CMOS sensors which are what are used in DSLRs. Depending on the length of the exposure, CMOS sensors can use different timing circuitry (on chip versus off chip) so a bias frame taken at a very short exposure will not be representative of the bias signal in a multiple minute or multiple second exposure. This is why you can get all kinds of strange things happen when you use bias frames with CMOS sensors. The best thing is to calibrate both flats and lights with darks of exactly the same exposure time as the frames you're trying to calibrate. Also, remember that when you take a 1/8000 or 1/5000 second DSLR frame for your "bias", the sensor is active for a lot longer than 1/8000 s or 1/5000s. DSLRs achieve such short exposures not by activating the sensor for such short times, but by closing the second curtain or second shutter before the first shutter has completely cleared the frame. In reality, your sensor is active for something like 1/180s, 1/200s/ or 1/250s during the fastest exposure your DSLR is capable of. Another reason to not bother with bias frames. |
Well said, Arun. I wish I had met you 4 years ago! Bias frames certainly do introduce some crazy stuff in my stacks. Thanks for that expaination. |
Stuart Taylor: According to some people on Cloudy Nights, the dark frames even worse for Nikons, even if the temperature matches or close to what the lights were taken, they don't work well. They work to take away Amp glow, if you got any. As for my experience (see some of my images) Pentax K70 does automatic noise reduction above ISO 600. This is confirmed by photos for photons website. My read noise literally drops to pretty much 0 beyond ISO 636. This is a feature that doesn't require even auto-dark frames or auto-noise reduction. It will be done and doesn't take extra time. https://www.photonstophotos.net/Charts/RN_e.htm |
Arun H.: Yes and no. It depends. On my ASI294MC I had worse results while NOT removing the master bias frame from the master dark frame although the suggestion from ZWO was not to. OTOH, the Nikon D5100 seems indifferent which ever way you do it. I just keep doing it for consistency sake and also because I suspect there is thermal drift in the dark signal which I cannot completely zone in as the actual sensor temperature isn't really controlled or even known. |
Arun H.:I have always used darks and will continue for noise and hot pixels sake, but I have dumped my bias frames as they have always complicated my stretching for some reason. wow! this is quite a revelation (as I only use a DSLR)! Thanks |
Andrea: John Upton did a very detailed quantitative test on the ASI294MC Pro specifically. It goes into specifics of the differences in timing circuitry for different exposures etc: https://www.cloudynights.com/topic/636301-asi294mc-calibration-%E2%80%93-testing-notes-thoughts-and-opinions/ It was this reading that improved my knowledge of how CMOS sensors work and why taking bias frames is not really recommended. I also use a Canon 5D Mark IV on occasion. I had lots and lots of trouble getting rid of banding in my early days when I was using bias frames. Going to only subtracting darks fixed the issue. These are John's recommendations. They are specific for the 294MC, but the general concept is useful for all CMOS sensors: "Putting It All Together All of my testing has lead me to the following conclusions. I intend to implement these in my usage of the camera if I ever see a string of clear nighttime skies again.
I'm afraid we'll have to disagree on this one, 'cause I can't reconcile those findings with mine. Note that, however, my camera is 2020 vintage and I don't use ASCOM drivers nor offset. Nor his recommendations with mine. This said, everyone is very free to do as they wishes, and I don't see much difference in either way, for a CMOS astro camera anyway. I have my reservations with DSLRs, especially the older ones. |
Hello, this is a very interesting topic, @Stuart Taylor. Thanks for bringing this one up. Coincidentally, I have also been dealing with the calibration issue for quite some time. I currently use a Canon EOS 80D (CMOS) and calibration has always puzzled me. In addition, you can find so many, sometimes divergent or even contradictory statements on the net on this subject. I don't know if you are using PixInsight. With the latest release of PixInsight (1.8.8-8 ) a very detailed and up-to-date description of the calibration process (ImageCalibration in PixInsight) by @Edoardo Luca Radice (Astroedo) appeared for the first time. I would even call it an excellent tutorial on calibration in general. Among other things, he discusses when the use of bias frames makes sense and when they are more likely to cause additional problems (with regard to CCD and CMOS sensors, amplifier glow, etc.), when dark frames should be used (calibrated and uncalibrated), dark flats, dark frame optimization etc. Maybe @Edoardo Luca Radice (Astroedo)'s "tutorial" is available outside PixInsight (if you don't have access to the latest PixInsight release)? Another very detailed paper on this topic was written by Craig Stark ("Profiling the Long-Exposure Performance of a Canon DSLR" ). He meticulously examines the unexpected behavior of DSLR cameras. Although he mainly deals with Canon cameras, the general conclusion is that it is worth the effort to investigate the behavior of one's own camera, if calibration is taken into account, since general statements are difficult to make due to the apparently diverging behavior of different camera models. In my opinion, Craig Stark's paper describes excellently how to test the behavior of the sensor yourself and what conclusions you can/should draw from it. Best regards - Thilo |
Ooops, some weird emojis were automatically inserted into my text above (because of a closing parenthesis). The actual PixInsight release I was referring to is 1.8.8-8. --- Update - they're corrected now. |
gosh this is really going in some unexpected directions then! It's beginning to look as if I won't need dark frames OR bias frames with my DSLR! That could save a bunch of time! I guess I'll just try stacking with and without them and see what works best @Thilo - no, I am not using Pixinsight (didn't know about it). Is it for stacking? I use DSS and Photoshop |
It's a heated subject (see what I did here? ![]() |
Just stacking the lights definitely does not produce the same starting point for post-processing in my circumstances; typically shooting 30-75s unguided subs in fairly light polluted (Bortle 7) skies. Both with a regular and full spectrum Canon EOS 700D. For me, I don’t really see the problem. I just take the scope of the mount for shooting darks and bias frames, which gives me ample time to break up the mount and other equipment. I do feel it matters how long the subs are. For much longer integration times, the relative contribution of read-out noise to the overall noise is different. Roger Clark has a rather extended explanation of the different steps here: https://clarkvision.com/articles/exposure-f-ratio-aperture-and-light-collection/ |
This thread is really interesting... Thanks for it. I'm reading here since yesterday and I did a test with data I collected last week to have a practical view on it. I stacked all possible (partly senseless) combinations. If anyone is interested to see the results (full resolution JPGs, 100% quality): https://astrob.in/rue1z5/0/ (stretched) / https://astrob.in/4lqqk3/0/ (ABE and stretched) I didn't upload TIFFs, since they are >100MB each. For my modded Canon EOS 70D (H-Alpha sensitivity 80-85%) and this particular session data (180s exp.) it seems that I do not benefit from Bias frames, like explained by @Arun H.. I think everyone has to test it for his own equipment, also with different session data... |
3
star-watcher.ch: Thank you for trying even the senseless combinations, this is a really helpful experiment for someone approaching calibration for the first time. For the reasonable combinations, maybe it will be more suitable to apply a low-order ABE (or DBE) with exactly the same settings and then compare. Most people discover improper calibration after removing this thin layer of light pollution from their images. And I totally agree, all of us should try this experiment! |
My Sony a5000 full spectrum and my Sony a7 seems only to need flats to remove dust and perhaps some slight vignetting. Darks does not change the results visibly. To increase resolving power with my oversampling I use Bayer/X-Trans drizzle 2x dropsize 0.5 (Astro Pixel Processor) |
Whether there is benefit to dark frame subtraction or not will depend on the characteristics of the sensor. There are two components to dark current - mean dark current, and the noise due to dark current Dark frame subtraction subtracts out the mean dark current, but does not, and cannot, subtract out the noise from dark current. The noise from dark current simply adds in a sum of variances manner to the noise from other sources such as read noise and photon shot noise. To reduce noise from dark current requires lowering the sensor temperature, there is no other method. If the dark current distribution in your sensor is spatially uniform, then there may not be a benefit to dark frame subtraction, since the mean dark current is simply a constant bias or pedestal that can be handled by tools such as background extraction and color calibration. If the dark current distribution is not spatially uniform, then you will benefit from dark frame subtraction. Although you could, in theory, handle such non uniform gradients using things like DBE, dark frame subtraction will greatly simplify things. On my 2600MC Pro, the dark frames look (visually) very uniform, so I could, perhaps, get away without dark frame subtraction. My ASI 1600 MM Pro shows glow on one side of the sensor. Dark frame subtraction cleans it up nicely. |
