1.51
Andy Wray:The scope is currently outside under my telegizmo cover and it's raining so I can't take a picture of it. This is the latest picture I have from last week when I had it in and was doing some modifications. The imaging train is the following: ASI294MM-Pro - 1mm spacer - EFW - 11mm spacer - OAG - TSGPU CC - focuser From what I can tell: none. Except for the modifications I've done to the tube (Flocking, painting, lightshield). I also use Optolong 1.25" LRGB filters but that's not the issue since the spot shows even unfiltered. |
You did not understand me, light goes trought the primary mirror, from the bottom up, you do not have any caps on the bottom of the telescope. there is a primary holder, there are gaps on the bottom, you can close gaps on the bottom, light will still go trought the mirror itself, with source shining from the bottom. Even if it is covered with reflective material, the sides of the mirror are not, the break the light that comes from the bottom of the scope and it eventualy gets trought sides and get into the tubus, this is your problem, i know, i have same problem, and you can test it puting a light source on the bottom of the telescope, even with you cap industral or not on, you will see artefact very clearly, brighter light source, easier to spot the artefact. Judging by the frames you have your light source comes not directly from the bottom but a bite sideways, so it is very important that no light shines on your entire telescope not only on the top. Keep that in mind and you will never have problems like this Clear sky my friend!!! |
1.51
You did not understand me, light goes trought the primary mirror, from the bottom up, you do not have any caps on the bottom of the telescope. there is a primary holder, there are gaps on the bottom, you can close gaps on the bottom, light will still go trought the mirror itself, with source shining from the bottom. Even if it is covered with reflective material, the sides of the mirror are not, the break the light that comes from the bottom of the scope and it eventualy gets trought sides and get into the tubus, this is your problem, i know, i have same problem, and you can test it puting a light source on the bottom of the telescope, even with you cap industral or not on, you will see artefact very clearly, brighter light source, easier to spot the artefact. Judging by the frames you have your light source comes not directly from the bottom but a bite sideways, so it is very important that no light shines on your entire telescope not only on the top. Keep that in mind and you will never have problems like this Clear sky my friend!!! The mirror is not visible from the bottom. The entire bottom of my telescope is covered I have also flocked every bit that is exposed to light inside the mirror cell itself. I have NO light coming in from the bottom or around the mirror cell or it would show up when I take 5min darks. |
7.91
I would disagree. Flats do not remove light pollution or local light pollution which I believe is causing this reflection. If the reflection moves from taking the flat to taking the light no matter how good your flats are it will not correct it. This is why I see the "embossed" effect on the final calibrated stack. This also explains the far right dust mote since it is by far the most extreme of them all. Being in the far corner and being darker than the rest it would be more susceptible to inconsistencies in movement. As to speak to the tilt. Yes, you are correct. I had a tilt issue when running this test since I had to resort to using the skywatcher original two screw "clamp" mechanic to attach the camera. So the top/bottom inconstancies are due to this. I should have been more specific and saying "it should correct ALL the irradiation disuniformities due to the optics and image train". As for calibration, as opposed on taking them, I'd venture to suggest that you do it manually, thus you'll be sure what is what. Specifically: a. Take a series of flats with hystogram below the mid-range threshold. b. Take the same number of darks at the same gain of the flats (in case you change it from the ASI defaults) and exact same length. c. If you're using flat panel to take the flat use NINA to take the flats+dark flats. I'll reiterate: the only way you can be sure your flats are ok is if the correct themselves. Condition necessary but not sufficient, alas. Retrun to the issue you describe I have 3 newtons and none has anything anything similar, with plenty of light pollution left, right and center. On the processing side, first, using PI, create a master bias-dark from the dark flats (integration with no normalization and whatever outlier rejection method is most fitting). Then use the master bias-dark thus created calibrate the flats by just using it as a master bias. The proceed to integrate the stack of calibrate flat frames (integration normalization: multiply, rejection normalization: equalize fluxes). Sa as master flat. Then use a master-dark with integrated bias (so no bias removal) and this flat but no biases to calibrate the image. |
1.51
andrea tasselli:I would disagree. Flats do not remove light pollution or local light pollution which I believe is causing this reflection. If the reflection moves from taking the flat to taking the light no matter how good your flats are it will not correct it. This is why I see the "embossed" effect on the final calibrated stack. This also explains the far right dust mote since it is by far the most extreme of them all. Being in the far corner and being darker than the rest it would be more susceptible to inconsistencies in movement. As to speak to the tilt. Yes, you are correct. I had a tilt issue when running this test since I had to resort to using the skywatcher original two screw "clamp" mechanic to attach the camera. So the top/bottom inconstancies are due to this. I take my flats using FlatWiard with dark flats as well. If I use the master flat to calibrate one of my integrated flats I get the following: As expected it's a completely flat image. Indicating that the flats themselves work. As to processing, I don't think processing is the issue. I've tried integrating using DSS as well with similar results. |
7.91
That a good first step. Now I'd ensure that taking flats on a different tube orientation produces the same results. If not, something is tilting within you image train. If you think it already does, correct the issue and try again. |
1.51
andrea tasselli: I have a Baader ClickLock coming tomorrow that should solve the temporary tilt issue. When I got my new CC it was to large for my M54x1 adapter so I had to move from an entirely mechanical screw on connection to the ClickLock, which I've heard is the next best thing. I'll do some more daylight tests then. Since the midnight sun will soon ruin any attempt at getting images at night I'll have to try to get to the root of it using only the flats as feedback. |
11.01
Apologies if you have already covered this, but have you recently taken any shots without a coma corrector in the train? A 200PDS would not usually on its own create that dark centre effect, so just trying to rule the CC out of the equation. Also, do you have any light polution sources that you supect could be affecting your imaging? My scope sits just outside our kitchen window and my wife frequently walks in and just turns on the very bright lights (we have no blinds in the kitchen) and I still don't see that kind of effect. Obviously I get gradients, but nothing like yours. |
1.51
Andy Wray: I'll take some flats without the CC tomorrow when I have it inside for the ClickLock change. I have a weak memory of taking flats without the CC before and the problem was still there but don't quote me on that. My scope sits pretty permanently on my balcony in a bortle 7/8 area with plenty of local light pollution in the form of street lights and walkway lights that point straight up. I tried talking to my landlord about light pollution but they say it's up to the city, so looks like I am stuck with them. |
11.01
@Andy Wray Would it be possible to ask for some samples of your data? A light frame and a flat frame using Lum filter? Sorry, just seen this request. Here's a single flat capture and a single light capture from my most recent image. I applied an STF stretch to each before saving: Also: I think I have the same tracing board as you and had to put it on its lowest setting and add a T-shirt on the scope to get anywhere reasonable exposure times. Lastly: the very dark gradient at the very top left is my OAG intruding a tiny bit into the image. |
1.51
Andy Wray:@Andy Wray Would it be possible to ask for some samples of your data? A light frame and a flat frame using Lum filter? Could you make these available for download? I'd like to take a look and compare in Pix. |
A long shot probably. I have had somewhat similar-looking vignetting problems in the past that turned out to be related to the darks rather than the flats. I was using a masterdark comprised from frames at a slightly different offset value than the lights. I was usinga ZWO camera with Sharpcap and didn't at the time know that the 'brightness' referred to the offset value and hadn't been careful to match lights and darks with respect to this parameter. Tim |
1.51
Tim Hawkes: I did retake my darks a few weeks back just in case this was the issue but nothing's changed. |
11.01
Andy Wray:@Andy Wray Would it be possible to ask for some samples of your data? A light frame and a flat frame using Lum filter? I've never used Google Drive, but maybe this will work: https://drive.google.com/drive/folders/1zGcZlSHd-77PygcELg8bVGPjYn_gAV5A?usp=sharing |
1.51
Andy Wray:Andy Wray:@Andy Wray Would it be possible to ask for some samples of your data? A light frame and a flat frame using Lum filter? Wow, yours are so much cleaner than mine... Is your OTA completely stock? |
11.01
Andy Wray:Andy Wray:@Andy Wray Would it be possible to ask for some samples of your data? A light frame and a flat frame using Lum filter? Yes it is . I even ditched the dew shield because it wasn't helping much and was adding weight/mis-balancing. I had issues initially when my neighbour would leave his bedroom lights on upstairs, but thankfully he seems to be going to bed earlier nowadays. Also, where in the world are you? Maybe someone near you could loan you the skywatcher CC to see if it fixes the issue? |
1.81
Sorry if this was already covered... I had really strange flats from my 10 inch newtonian for a while - finally figured out it was light from the back end of the scope around the cooling fan on the primary mirror. I have to do flats while still dark, or blanket the back end of the scope - even putting some shade structures on the back wasn't enough to stop it. To figure this out, I setup the scope for ~1 second exposures with a really high gain, then went around the scope shining a really bright flash light on various parts until I saw the same patters. (a light leak detector). good luck this one seems like a tough one. |
1.51
Andy Wray:Andy Wray:Andy Wray:@Andy Wray Would it be possible to ask for some samples of your data? A light frame and a flat frame using Lum filter? I'm based in southern Sweden, don't know of anyone around me who has a Skywatcher CC Brent: This has already been brought up and is not it. |
2.11
A couple of random thoughts that I didn't see mentioned in the thread thus far:
I'm wondering if you had some moisture in your sensor chamber that dried and left a translucent film. Unlike a dust or dirt particle that won't let any light pass, something like this may be mostly transparent to the bright light of a flat but may block a higher percentage of the (minimal) light from an imaging sub. I've had moisture in my CCD chamber in the past that dried, but it didn't leave a film. I made a gif on this thread showing the condensation drying over time: Maybe you had something similar but it left a film on the chamber glass or on the sensor itself? Or a smudged fingerprint? |
1.51
Dave B: Interesting idea, it does look very similar. Now that I recall I remember that the package I got the camera in was quite battered by rain and was barely holding together. That might have caused damage that I haven't noticed before. I'll try and switch out my camera to a DSLR I have laying around at test with that. @Andy Wray I took some flats without the CC and it stays the same. So I can rule that out. |
1.51
Okay... Progress? I removed the camera from the CC and instead attached an old DSLR to it to test if it was the camera or the CC. Turns out it might be the camera. Everything is the same until after the CC. Where there now sits a Nikon D3100 instead of my imaging train. I took flats using the 1/3 histogram rule and 50% histogram: these are the results from the DSLR: Stretched (before DBE): Stretched (after DBE): There may still be a slight shadow in the upper third part of the image (I believe this to be due to me knocking it out of collimation with all my testing), but nothing close to what I saw with the camera. |
7.91
Since you removed the camera, have you looked into it? Is there anything weird? You can test the camera on its own in daylight by making a pin-hole camera out of any adaptor that fits it, foil and a very tiny prick with a needle. You can then test on daytime objects, such a white wall to see if there is any trace of the shadow. |
11.01
Okay... Progress? Progress indeed That's a much more typical 200PDS flat. I would say you have definitely found your culprit as you'd already ruled out the filters/filter drawer and the OAG would not cause the effects you were having. |
1.51
I am hesitant to say that I've solved it since I have yet to try my fix under the stars. But the flats look drastically different to what they used to. I removed the camera (only the camera) from the imaging train and looked down the light path from behind my filter and noticed a small ring around the secondary mirror (see image, marked in red). So just to test I built a cap (image attached) that slotted into the top of the CC and flocked it and kept on adding layers until I could no longer see the small ring when looking from the cameras position. Taking new flats with this configuration yielded the following: I think this is a significant improvement as the "dark spot" is no longer visible and the field looks more even than before. However, these are just preliminary results and I'll have to test next clear night to see if it has actually made a difference. Reflection: CC cap: |
11.01
I must say that you shouldn't need to do all this flocking on what is a widely used OTA. I personally would focus on the camera for now as the flats using it look very nasty. You also took very nice flats with your DSLR. Why did you decide to go back to the flocking solution out of interest? Also, (related to your previous post) I wouldn't do a DBE on your flats as you are effectively destroying the evidence that you are trying to analyse. Here is your flat from your DSLR after a boosted STF. It looks very good to me: and here is a standard STF of your image above from the mono camera: |
