2.86
Hi AstroBinners, I have a 20-second video. As it came from PIPP it weighed about 8GB Then I packed it down to 200MB file thanks to H265 Im on AstroBin Lite, so my limit for uploading stuff is 25MB What are my chances of compressing this video below that mark? Its 3024px by 4032px at 12fps A bunch of iPhone frames combined into a video using PIPP Plz help |
4.20
try this https://riverside.fm/video-compressor it says it's lossless |
2.86
4.20
try this too https://videoconverter.wondershare.com/compress/lossless-compression.html |
4.20
going to sleep if that software doesn't work, I'm sure someone else will help hope it works; looks like good software see you later |
2.86
try this too https://videoconverter.wondershare.com/compress/lossless-compression.html *That software you recommended looks nice, but the highest resolution it has would be 4096 by 2160 And my video is 3000 by 4000 So it doesn't work - it crops and I don't want that |
4.37
My recommendation is to use ffmpeg, you can adjust compression and resolution to reach the desired file size. https://unix.stackexchange.com/questions/28803/how-can-i-reduce-a-videos-size-with-ffmpeg Works in Linux and windows. |
