Hi, Does anyone know if it’s possible to power the Asiair plus with the DC12v iOptron output ? See attached pic. Many thanks ![]() |
Hi CieloBlue, From a quick review of the iOptron manual, it looks like this 12V output is meant to power the LED for the polar scope. My older CEM60 has a similar connection, although the voltage is not labelled. Given that there is no current output rating on this 12V connection and the barrel jack may be the wrong size, I would avoid trying to power an ASI Air from this connection. The Air may need a lot more current than the CEM26 can provide which will cause problems for your mount electronics. CS, Bob |
If you refer your mount instruction manual, it is mention the maximum allowable amp of the output 12v. for the cem70 it is totally 3A for output 12v together. |
Many thanks for the info, that’s very hopeful . Cielo |
