Additional comments re: Gain & offset settings for the 2600MC Pro ZWO ASI 2600MC PRO · Stargazer66207 · ... · 3 · 294 · 0
Stargazer66207 1.81
Group:
There has been a lot of discussion regarding the gain and offset settings for this fine camera. First, I am not an expert nor an imaging guru. I just like to produce "pretty pictures".  I have had my 2600MC Pro in operation since last fall. When I first started using it, I always used the selection in the ZWO setup menu of "lowest read noise", which produces a gain of 100.  The images produced with this setting were pretty, but a few months ago I read an article on one of the imaging forums about the advantages of using Zero Gain.  On my next imaging session, when I opened up the setup menu, I selected Zero as the gain setting, and saw that this is also the gain that results from using the menu selection "Highest Dynamic Range".   I have used this setting since then. One thing I noticed is that at this setting the stars do not seem to be over-saturated, and the star colors are much richer.
By the way, I should mention that my imaging site is Bortle 3, and I always use sub-exposures ranging from 120 seconds to 240 seconds.
Just thought I'd pass my thoughts along, as added fodder to this discussion.
Stargazer66207
AliAlhawas 1.20
Well.. It depends on several things such as site bortle , seeing , temperature, do you have more time or you have only 2-3 hours, target type..
I tried both gains Zero and 100,, you will get something and lose something.. !
In Zero gain you will get dynamic range but slower and with noise,
In gain 100 you will get less noise and faster but you will lose HDR..
As I am limited in time and site is bortle 2 I always use gain 100.. but lose a little bit of HDR.
So.. before you start your imaging session, do 2 images as a test.. one with Zero and the other with 100 and see which is better for you.
Good luck!
DaleChamberlain 0.90
I am in Bortle 5 and always use Gain 100. Plus I do a lot of narrowband imaging.
Stargazer66207 1.81
Dale,
If you're doing long exposures for narrowband, then Gain 100 is probably a good idea. The only filter in my image train is an IDAS UV/IR blocker.
Stargazer66207
