1.81
Hi all, Today I received my Askar duo Magic Color 6nm HO + SO. I'm really excited to try them. I actually using L-eXtrem duoband filter and I extract Hydrogen and Oxygen and assembly them for H-HOO combination. With the Duo Magic Color from Askar filters, I have the possibility to make SHO assembly. But, I'm questionning about the time exposure from OIII which will be 2 times higher than H and S: - This 2 times higher exposure time will impact the data processing in PixInsight ? - There is any "tips" with a higher signal on OIII or it is unnoticeable during data processing ? Thanks for for advice, |
1.81
Sorry for the mistake about the location of the post. I don't know how to delete it ... |
0.90
Hi Martin, if you use APP you can seperate the channels during processing so you get one H and one O or one S and one O. If you have objects with a lot of O you can use it in addition, otherwise you can use O only one time. Another possibility is to reduce blue and green in postprocessing like in PS by ~ 30-50%. =HwtZe=jCAhz ChMk0b C1N51c=ryNqvbMany roads lead to Rome CS Werner |
