Deepsky stacker help Luc Coiffier DeepSkyStacker (DSS) · Alan Hancox · ... · 35 · 788 · 18
astropilch 1.20
Hi Rick
I`ve tried stacking 12 frames plus 1 master flat / dark flat and dark. I don`t think my flats are working. Tbh i`m struggling with them. Here is a snap shot of my stack...
Oh i`ve tried adjusting the threshold and star detection to include less stars. I`m imaging with an RC8 so the FWHM will be pretty high anyway.
astropilch 1.20
I dither every 3rd or 4th frame...
rveregin 6.76
Are you still seeing the problem with the fewer frames above? How many stars are you getting on average? What is the % background. And what is the star threshold?
Note that bad flats will show non-uniformity in the image, but would not result in the narrow histogram you are getting, it would actually broaden the histogram. So this is not the problem I think with your stacking.
As I mentioned, if you want to load this set of lights (if it still shows the issue), a flat, dark and dark flat somewhere I can access, I can take a look and see if I have the same problem as you. It is difficult to troubleshoot from a distance, as you can see.
Rick
astropilch 1.20
Here is a screen shot of a stack i took last night. 25 x 180 secs with darks, flats and dark flats. Seemed to work fine is this case.
rveregin 6.76
So you are not seeing the problem with this smaller subset, as this looks perfectly normal--but was this selected from both nights where you had problems?
And are you still seeing an issue for the full stack over both nights?
Rick
astropilch 1.20
Hello Rick
Well i`ve managed to get the stack to work. I had to be ruthless with the subs and up the star detection and the threshold. In the end i manage to get 61 to stack over 2 nights. I`m processing the result as i type. The result still isn`t great due to poor flats, i`m still struggling with those with this camera / scope combo even though they look fine they dont remove all the dust motes. Time for a clean i think....
Thanks very much for all your assistance...
rveregin 6.76
That's great Alan! DSS does require good stars to work. There are some other programs that are more forgiving in stacking with poor stars. But then, if the stars and thus subs aren't good, it doesn't really help to be able to stack them.
Good luck with your flats--if you have any questions on flats let me know, I've gone through the school of hard knocks with flats, as have many others--they can be frustrating.
All the best
Rick
astropilch 1.20
Hi Rick
Here is the 61 frame stack. As you can see there are a few issues with the background. I`m using sky flats in NINA with a target of 26-29K ADUs. I`m not sure if my chip is just too dirty?
Any ideas?
rveregin 6.76
Alan Hancox:
Hi Rick
Any ideas?
HI Alan, It looked like from what you sent that you did do dark flats and darks? Make sure that the flats and dark flats have all the same settings, gain, exposure time, temperature, etc. And like-wise that the lights and darks have all the same settings, including temperature.  It is best to have the same gain for flats as for lights--of course this means exposure will be different. But cameras respond very differently with gain, there are non-linear things that go on, while exposure is very linear, so makes less difference. Good if the flats and lights also are at the same temperature, as temperature effects are non-linear.
To set the adu target, I look at the histogram. Depending on the light source and camera and filters, the peaks for different colors are generally quite different. Generally for me the green peak is to the right, blue in the middle, and red toward the left. What you need to ensure is that the peak to the right, generally green, is not clipped on the right, and the lowest peak is not clipped on the bottom end on the left. In fact, keep all peaks right down to the baseline between about 15 or 20% to 80 to 85% of full well, to ensure you are in a nice linear region. Don't worry about where the average luminance is, it is only important that all signals stay away from the edges. I use Sharpcap to see acquire and do the histograms, I presume NINA can also do the full color histogram.
The other possibility is that the dust donuts are moving around a bit. This could be because focus or something got shifted slightly in your optical train. For example if you take your sky flats in the evening, then take images that night, the temperature change can move the focus in your scope, this can shift the donuts a bit. This time of year for me here near Toronto is bad for this, can be 25 C during the day and 8 late at night. Or that the donuts just moved a little on its own, for example the vibrations from moving the telescope if it is a mobile setup. Those are the worst, you get these creepers that move constantly--best is to try to clean everything off when that happens.
Let me share how I monitor and do my flats. I have a simple artist's light panel for tracing. Mine is A3 size for my C925. Less than $50 when I got it on Amazon, smaller sizes are cheaper. It doesn't need to be super uniform as I put in on top of my dew shield where it is way out of focus. The advantage to this is I can run flats anytime. My camera is cooled so temperature of the camera is always the same. So this way I can do flats after my telescope is equilibrated and focussed for the night. Takes only 2 to 3 minutes to do 50 flats. Then, during the night, I setup DSS and actually run it with my flats and darks. I continue to look at new subs during the night. This way I can check my FWHM, stars, scores, what the images look like, background continually. It has happened that a dust bunny suddenly moved during the night. I immediately ran a new set of flats, then continued imaging. Nothing worse that looking at the images in the morning to see a huge dust bunny in half your frames. One might get away with running a new set of flats the next day, but a moving bunny can move again. Anyway, after a long night out I hate a nasty surprise the next day, this eliminates that issue.
So if you have not taken apart your setup you could try a new set of flats. Again, the donuts may have moved during the night, it sometimes can be a pain to find out which frames are okay with the old flats, and which are better with the new flats.
Hope all this helps.
Rick
astropilch 1.20
Hi Rick
I`ve just taken the camera off the scope and cleaned the filter which was pretty dirty and the camera again pretty dusty!!! Hpefully it should make it a bit easier. I`ll invest in a flats panel sadly the one i currently use isn`t quite big enough. I`ve never used Deepsky stacker live, i assume its like the live stacking part of Sharpcap. Food for thought.
Thanks again
Alan
rveregin 6.76
Alan Hancox:
Hi Rick
Thanks again
Alan
Actually Alan, I do not use DSS live. It typically crashes on me--the problem is that when image files are still being written it can try to access the image file while it is locked or not finalized and then just crashes. I haven't though tried it with v5, so the bug may have been solved by now. Also, it doesn't use flats and darks. I just open DSS as normal. I load flats, dark flats and darks and one light, to make my master flats and darks. Then I open DSS with the master flats and darks I just made, and choose my first lights in my acquisition folder. And run DSS. I do an inspection, delete any real bad files. Then I load more lights that have accumulated since then and restack, and review. You can keep adding lights and rerunning without closing DSS, at least in DSS v5. I set it to overwrite the saved file, so I don't end up with a string of saved stacks. And you can do a stretch in DSS anytime to follow what it looks like roughly. If the night is going well, I might acquire for 30 minutes or more before doing another DSS run. If it is the start of the night, there are lots of clouds, or other issues apparent, I run DSS more frequently so I don't let a problem accumulate a bunch of bad subs. A bit manual, but well worth it. DSS v5 is really fast, even 200 frames can be registered and stacked in less than 5 minutes.
Rick
