Selling asi2600mm pro to get asi294mm pro ZWO ASI294MM · Marc Monarcha · ... · 50 · 1633 · 0
This topic contains a poll.
Sell 2600mm pro for 294mm pro for exceptional seeing?
yes
no
monarcha 1.51
Say you live in a place with exceptional seeing and find yourself under sampling when using the 2600mm with all the telescopes you own. Would you consider selling the camera and buying instead a 294mm pro to use in bin1 mode?
andreatax 7.56
Get a bigger scope.
monarcha 1.51
Get a bigger scope.
Not planning on getting 2000+ mm focal length with a decent f ratio and end up having to buy a new mount. It’s outside the budget and my area of interest. I’m happy with the 250-1800 focal range that I have currently, just want to optimise
andreatax 7.56
Marc Monarcha:
So you have access to a sky with seeing better than 1.2" on average?
monarcha 1.51
Marc Monarcha:
Yes. It’s in Ehden, Lebanon. I go even higher up in the mountains usually so even better than what you see on websites for seeing conditions. Quite lucky
andreatax 7.56
Any image you are willing to share?
monarcha 1.51
The images I have so far are all posted here
AstroDan500 4.67
Your images look very nice. Why would you want a lower pixel inferior camera that needs a lot of calibration frames is a mystery to me, sampling or not.
andreatax 7.56
Marc Monarcha:
All I can see from your gallery are taken with a 250mm refractor or I am missing something?
monarcha 1.51
Dan Kearl:
Thanks! I’m interested in more detail out of the images. Sacrificing FOV is no issue for me. Nor is the addition of calibration frames. The question I guess now is whether the increment in sharpness (or whatever the technical word for it) I get from the smaller pixels is worth the sacrifice in dynamic range. I would also be able to crop more with a 294mm pro sensor, which means getting closer to smaller galaxies or nebulae for example.
monarcha 1.51
Marc Monarcha:
I have yet to use my quattro 200p or vixen vc200l
AstroDan500 4.67
Marc Monarcha:
Dan Kearl:
Maybe I know nothing but you cannot crop a 24mp image more than a 52mp image.
monarcha 1.51
Dan Kearl:
I’d also have spare money to get a planetary camera with what’s left of the sale
AstroDan500 4.67
Marc Monarcha:
Dan Kearl:
So you are buying used cameras after you sell yours because a 294mm is $1299 and a 2600mm is $1799 and there is no way you are getting more than 75% selling your 2600.
monarcha 1.51
Dan Kearl:
Marc Monarcha:
Dan Kearl:
Cropping depends more on your pixel density here. Besides, the 294mm pro also has more mp when in bin1 mode
monarcha 1.51
Dan Kearl:
Marc Monarcha:
Dan Kearl:
Most likely. Also, where are you getting those prices from? I thought the 2600mm pro was sold for 1999$ on the zwo website
andreatax 7.56
Marc Monarcha:
For whatever reasons you may want to crop an image pixel counts has nothing to do with it, only how much of the FOV you are willing to sacrifice.
monarcha 1.51
Marc Monarcha:
I disagree with the first part of your statement. You can crop more on a 60mp full frame than you can on a 20mp full frame, and that’s simply because of “image pixel count”. Between the 2600 and 294, given the sensor sizes AND the pixel size, you can crop more on the 294 bin1. So for the same fov from either of those two cameras (all else like telescope being equal), you can sacrifice more on the 294. And that has to do with the combination of sensor and pixel size, and the ratio of those two.
andreatax 7.56
Marc Monarcha:
I'll have to disagree, as you should compare apples with apples so the same FOV. In the specific of a 2500 vs 294bin1 you already cropping your FOV (with the same FL). If the former was brought to cover the same FOV as the latter the difference is that one 2600 pixel covers 1.6 pixel of the 294 in bin1 mode, so you loose this much in granularity but this is essentially irrelevant (few arcseconds to fraction of arcseconds).
monarcha 1.51
Marc Monarcha:
I actually am comparing apples with apples and saying that for the same achievable FOV, you get more resolution out of the 294 bin1. So to go back to the initial topic, I can achieve higher resolution from a 294 bin1. Nothing new there…I was looking to see if someone had any input on dynamic range, maybe full well depth and if it’s reason for concern. Maybe also something else that I should consider, aside from FOV and having to take calibration frames
StewartWilliam 1.81
·  6 likes
Why are you even bothering to ask on here, as you have already made you mind up to do this as you are arguing  with anyone that tells you it’s not a good idea, so that is a sure sign you have already decided….🤷🏼‍♂️
monarcha 1.51
AstroShed:
I haven’t made up my mind yet…just weighing the pros and cons, maybe looking for something I’m missing as I said! Also, no one said it was a bad idea😂 someone was wondering why I’d do it. They, just like me, seemed open to learn, right or wrong
andreatax 7.56
If you think is worth the effort, then by all means go for it. Me, I wouldn't be doing it. And I have the camera in question.
AstroDan500 4.67
I don't think its a bad idea, shoot what to want to shoot.
if money matters,  you are unrealistic about what a used camera is worth.
You won't sell the 2600 for enough to cover the cost of a new 294 if that matters.
StewartWilliam 1.81
Marc Monarcha:
AstroShed:
Well the poll you started gives you your answer, look at those percentages….🤷🏼‍♂️ I rest my case…
