Hi How would you describe in few words/sentences what we do, when we make/produce an astro-image from raw frames to the final astronomical image?
Some call it image manipulation?
What are the right words to use, that best descibe what we all do in that process?
Thanks in advance. Br. Niels
I call it post-processing.
Hej Niels. Der vel ingen der rigtig ved hvad der er rigtig eller forkert, hvem siger at Hobbel paletten er korrekt (altså farvemæssigt) så det er i bund og grund op til den enkelte at gøre hvad man syntes rigtigt!! Nothing right nothing Wrong.
Hej Morten 😊 "Der vel ingen der rigtig ved hvad der er rigtig eller forkert".
venligst spørgsmålet var ikke hvad der er rigtigt eller forkert i processen, det var bare et spørgsmål om hvad det kaldes, det vi gør?
F.eks. Er billed manipulation det bedste udtryk at bruge.
Mvh. Niels
Hej Niels, "From image capture all the way up to post-processing." Mvh. Robert
Tja det kan man vel godt kalde det. Det dækker vel egentlig det hele i processen. Hvad har du gang i for tiden?
Ikke noget, vejret er jo noget lo*** i DK CPH området, derfor indlægget😊
Hello, Niels, I call it a personal "workflow": the whole process is individual and subjective. This is not primarily about scientific work with given standards. Best regards, Thomas
Hello Niels, Data reduction and integration is the scientific part for which you can use the word development, reminiscent of the film era. For the rest of the process you can use the term post-processing.
Some call it astrofaketography!
Niels V. Christensen: What are the right words to use, that best descibe what we all do in that process?
Hello Niels. I call it having fun, and my wife calls it wasting time. It depends on your point of vue 🤔
JF
to create to post a reply.
